problems removing gauge cluster and front cover
Old Jan 3, 2004 | 12:46 AM
ford390gashog's Avatar
ford390gashog
i need to remove the gauge cluster and the plastic cover that holds the gauges in place.i un bolted all the bolts but the wiper washer **** and headlight **** prevent it from comming off all the way.can someone help me the truck is a 1975 ford f 150 supercab.
Old Jan 3, 2004 | 12:48 AM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
searching *Wiper ******* brought up this in the search engine here.
https://www.ford-trucks.com/forums/s...52B%25252Bknob
Old Jan 3, 2004 | 12:51 AM
biz4two's Avatar
biz4two
The headlight switch has a release behind the dash. Look under and you should feel it. Push it as you pull out the **** and presto. The windshield washer **** should just come off (I think any way...but it is late) Sorry can't help with that.
Old Jan 3, 2004 | 12:59 AM
Mil1ion's Avatar
Mil1ion
Very close but There are a couple of Technical points that you missed.
One is the battery should be disconnected and the other is
the headlight switch should be pulled to the headlights on position,then depress the button and then pull the ****/shaft out
the rest of the way.
Doing this makes the **** & shaft slide out really smoothly.
Not doing it this way causes one to Yank & pull with frustration.
Old Jan 3, 2004 | 01:02 AM
LxMan1's Avatar
LxMan1
You may have to use something to push the clip (just behind the ****) towards you as you pull the **** off.
If you reach up under the dash, you should feel a small button in top of the headlight switch. Push it down and wiggle the **** around and the ****/shaft should pull out.
Just a note, your headlights will be on unless you either reinstall the **** or unhook the battery.
Jimmy
atomicjoe23
28
Jul 12, 2015 06:52 PM
degdawgs
Dec 5, 2005 12:09 PM
snooziums
1966 - 1977 Early Broncos
Apr 9, 2005 09:06 AM
orange78oval
1978 - 1996 Big Bronco
May 3, 2004 08:42 PM
TheMachfather
22
Jan 21, 2004 10:05 AM
