How do I remove the headlight knob?
Old Dec 22, 2003 | 07:39 AM
TheMachfather's Avatar
TheMachfather
How do I remove the headlight ****?
I need to take the headlight **** off of a 78 so I can get the plastic gauge cluster thing off. I'm gonna make a billet aluminum one and I don't see what gets that **** off. Does it release from the back like some classic stangs?
Old Dec 22, 2003 | 08:04 AM
tamarackstyle's Avatar
tamarackstyle
There should be a clip within the **** which wedges itself around the shaft. look at the underside of the **** and you will find a slot. Take a small screwdriver in the slot pulling towards you as you pull the **** off.
Old Dec 22, 2003 | 08:13 AM
canda250's Avatar
canda250
headlite ***
I have 2 1979 Fords .It should be like mine . There is a white plastic button you can,t see on top off the **** assembly behind the dash. You have to reach up behind the dash and feel for it .Push down on it and the stem comes out . It should be the only thing that moves. I also have a 1993 Cougar and it is the same way.
Old Dec 22, 2003 | 10:41 AM
Mil1ion's Avatar
Mil1ion
Tamarak, that's the way the wiper **** comes off.
The trick to the headlight switch is
You set the headlight switch to headlights on position THEN depress the button and pull on the ****.
Old Dec 22, 2003 | 01:09 PM
CmprSpecial's Avatar
CmprSpecial
Snake your hand up under the dash and feel for a little button (like in the above mentioned picture).
This is how I did it:
Press the button and pull the **** out gently till it stops. You should be able to feel the button move a little when the **** stops.
Release the button and push the **** in ever so slightly, then repress the button and the **** should pull right out of the dash.
Good luck.
Old Dec 22, 2003 | 01:47 PM
BigBully's Avatar
BigBully
and you can push it back in enough to turn the lights back off but dont push too hard or it will lock back in.
Old Dec 24, 2003 | 07:53 AM
tamarackstyle
sorry for the misleading info.
Old Dec 24, 2003 | 08:19 AM
73Custom's Avatar
73Custom
You're thinking of the wiper ****, that's how it comes off...
Marty
Old Dec 24, 2003 | 11:16 AM
ivanribic's Avatar
ivanribic
. . . and all this time I wondered why Ford made ***** that strip out when you remove them. You DO learn something new every day!
Old Dec 24, 2003 | 12:10 PM
Mil1ion's Avatar
Mil1ion
Quote :
Cmp Special.
Cmp spe,
I used to do it the way you described it.
Maybe to humour me, you could try removing it the way I mentioned.
with my way, there is no finessing the button and slide out shaft.
It is <> pull the switch **** out >stop < >then Depress the button and pull the **** out at the same time.
Old Jan 5, 2004 | 09:18 AM
CmprSpecial
Mil1ion,
Sorry for taking a long time to answer.
I had trouble using your technique, don’t know why. The shaft lock kept hanging on the button preventing release. Pressing in slightly after releasing the button seemed to correct the issue.
Old Jan 10, 2004 | 09:28 PM
79pos's Avatar
79pos
I was just wondering were you successful in makinf the cluster, if so how did you do it
Old Jan 10, 2004 | 10:57 PM
Mil1ion's Avatar
Mil1ion
That's weird :
When you say push back in , do you mean like a 1/16" or halfway > all the way back in?
Again, I pull the **** with shaft all the way out >
then Depress button and pull it out the rest of the way, slowly
Old Jan 11, 2004 | 01:36 AM
swann79's Avatar
swann79
Some of these ***** are just a little finicky... they just need finesse... like my ex-girlfriend...
Old Jan 12, 2004 | 07:20 AM
CmprSpecial
Originally posted by Mil1ion
That's weird :
Push in just a little. It more like taking the pressure off the latch that holds the shaft in.
