Sponsored by: Real Truck
speedometer problems
Old Sep 26, 2002 | 07:46 AM
FortyFords's Avatar
FortyFords
Old Sep 30, 2002 | 09:38 PM
yz429's Avatar
yz429
I have recently noticed on my '99 f250 4x4 v10 that the speedometer does not register below 20 mph. If I am traveling below 20mph, it remains on zero. The moment that the truck is traveling above 20, the needle jumps up. As I slow down, the needle is normal until 20mph, and then it drops to zero. Does anyone else have this problem? What could be the cause? It registers fine above 20mph. My ABS light is also on. Could the two be related?
Old Sep 30, 2002 | 09:59 PM
4x4x4x4's Avatar
4x4x4x4
Probably the speed sensor in the rear axle.It's my understanding that these can accumulate metal particles over time and affect it's function.Many have had luck simply cleaning them and then reinstalling the sensor.
Old Oct 1, 2002 | 07:39 PM
yz429's Avatar
yz429
Thanks for the advice, I think it helped me find my problem.
I cleaned the sender and reinstalled it. My problem is now worse. Now my speedo doesn't work until the vehicle is traveling 30 mph, and the shift from first to second feels like my tranny has a shift kit in it. If you stand on the pedal and the shift is after 30mph, it is smooth like normal. I am guessing that the tranny needs input from the sender to calibrate the shifts. I called Ford and the part is $25. I hope that this will fix my speedo and make the shifts normal again.
Old Oct 1, 2002 | 09:22 PM
V10man's Avatar
V10man
Sounds like your sensor for sure. $25 is a little high. I've seen them anywhere from $10 - $16 I paid $16.
Old Oct 1, 2002 | 10:48 PM
yz429's Avatar
yz429
Wow, that is cheaper. Is that an aftermarket or dealer price??
Old Oct 2, 2002 | 09:52 PM
yz429's Avatar
yz429
I replaced the sensor. It fixed the speedo and the antilock light went out!!! I am very pleased!!!!
Old Oct 2, 2002 | 10:10 PM
V10man's Avatar
V10man
Dealer price. Call a different dealer.
Old Oct 4, 2002 | 05:00 AM
chuckwpb's Avatar
chuckwpb
It was $25 in Connecticut too...
Chuck
1990 F250 V10 SD, Super Cab 4x4
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
