1978 - 1996 Big Bronco
Transfer case
Old Jan 2, 2004 | 04:47 PM
hotrodfeguy's Avatar
hotrodfeguy
Transfer case
I have a 89 EB bronco.I have given up on the push button FWD.I would like to change over to a manual shift transfer.Does anyone know what one will interchange? Also what one may be better (if there is one to look for) I have 5.0 AOD trans if that helps.
Old Jan 2, 2004 | 04:53 PM
bobcf's Avatar
bobcf
you should have bw1356 electricshift, bw1356 manual shiftwould be easyest. the bw 1345 should work as well.
Bob
Old Jan 2, 2004 | 05:06 PM
hotrodfeguy
OK what vehicle would they be in? Are those numbers the ID numbers ? Is there an ID plate or something to identify if i found the right one? I know jack about tranfers(i have worked on just about everything but them) Thanks for any help.
Old Jan 2, 2004 | 10:13 PM
Black Ford XLT's Avatar
Black Ford XLT
transfer cases
Hot rod , if u go to your local salvage yard they should tell u if (they have a computer system.When i went to look for a shift motor for my transfer case they gave me a print out of all vehicles that would fit my 1992 bronco (which included explorers) TR
Old Jan 3, 2004 | 03:42 AM
4wheelinbroncos's Avatar
4wheelinbroncos
bw1356 ford bronco and f-series trucks 1986-1996, bw1345 ford bronco and f-series trucks 1980-1986, np-208 will also work. all cases have what they is stamped on case 1356 is stonger
Old Jan 3, 2004 | 03:18 PM
battered_bronco's Avatar
battered_bronco
huh, none of the salvage yards i frequent have a computer
and if he don't like you its a pick your own type of thing
4wheelinbroncos
huh (this should be interesting...)
how do you figure a aluminum case chain driven BW1356
is stronger than my cast iron gear-driven NP205??
by the way i nor anyone(i have asked here and elsewhere) i have ever found have had a NP205 break bad seal maybe
but they(BW1356) are a sight lighter
Old Jan 3, 2004 | 03:21 PM
battered_bronco
oops sorry guy
you said NP208....not NP205 but i would say the NP208 is probally stronger but not sure
the chain will just snap or streach either way
Old Jan 3, 2004 | 05:39 PM
bobcf's Avatar
bobcf
here is some info
http://www.jeepland.net/tcase.shtml
Bob
Old Jan 4, 2004 | 06:20 AM
battered_bronco
the major problem with the NP205 is gearing its not that much (like a 2.6) but its enough
i try not to think about it since its a bich to change
don't like chains under touque ..yup they "work" but i could not trust them to be there when needed i want nice strong gears
although they put more pressure on the case
where as a chain drive stresses the chain instead or just looses some of the tourque through the tentioner
its cast iron case and weight is not a major issue(not ?50 lbs?)
what was the original question??
what motor are you running any mods?
sorry i keep thinking in terms of my truck
if you using a 302/5.0/351W/5.8 pick the lightest transfer case that will fit (like the BW ford used) unless you are running big tires on the original gearing not like you have a huge bottom end torque on it like a 400 or 460 or even a 300(or deisel for that matter)
Old Jan 5, 2004 | 03:59 PM
hotrodfeguy
Ok I went to the yard and here is what I found.Found a E7TA-7A(1356)(witch could not be found in the hollander book)case laying out of a truck have no clue what it came out of,but was a manual shift.Then I found a 89 F150 4WD with manual trans and manual tranfer case.They said thay can pull the truck out and get the ID numbers in the morning.Is there any change over between manual trans and auto? I was kinda excited about finding a 89 truck same year as my bronco.What do you guys think?
Old Jan 5, 2004 | 06:53 PM
steell's Avatar
steell
I think it will bolt right in (except for the shift lincage, which is no problem)
How much $$ ?
Steve
Old Jan 5, 2004 | 10:22 PM
hotrodfeguy
Well the one out of the 89 F150 is $150 with all the linkage included.I just want to be sure the transfer will fit/bolt up.
Old Jan 6, 2004 | 12:53 PM
steell's Avatar
steell
Bolt right in Decent price also. I don't know if your Bronco has the hole in the floor for the shifter, so you may have to cut one.
Steve
Old Jan 6, 2004 | 01:57 PM
RTM's Avatar
RTM
Just get the pan from the truck. It will have the hole in it already. It should just unbolt. I picked up a pan for my bronco that I plan on swapping a ZF in place of the C6.
Old Jan 6, 2004 | 07:31 PM
Lobuck76's Avatar
Lobuck76
Some of the f150's had 1356 w/ slip yoke rear output. Ron
RIKIL
Dec 10, 2014 09:39 AM
jdhudall
1997 - 2003 F150
Mar 28, 2013 06:59 PM
Percys Armory
6.7L Power Stroke Diesel
Nov 10, 2010 03:53 PM
tommypic
Feb 24, 2009 09:56 AM
FordCardinal
Aug 29, 2004 06:16 PM
