Leaking fuel line
Old Jan 2, 2004 | 02:57 PM
Nickiboy's Avatar
Nickiboy
Leaking fuel line
I have noticed that the front high pressure jumper fuel line (short rubber braided line with special connector at the lower front of engine) on my 95 PSD is leaking...... The manual says always use the correct OEM part when replacing these lines. However many of the fuel line mods that I read on are changing these lines to the black rubber fuel hoses with hose clamps to prevent air from entering the fuel systems............ The question is should I replace the lines with the factory replacement part or can I use the black rubber fuel lines with hose clamps to replace both jumper lines (high pressure and return line). what are the pros and cons ??
Old Jan 2, 2004 | 06:20 PM
Nickiboy's Avatar
Nickiboy
Its the fuel line jumper blue and gray
Old Jan 3, 2004 | 05:59 PM
Nickiboy's Avatar
Nickiboy
C'mon guys............ need your help here !
Old Jan 4, 2004 | 09:00 AM
Nickiboy's Avatar
Nickiboy
Maybe I should've worded this differently.
musicars
Sep 23, 2014 08:54 PM
Robbieo11
Jun 20, 2014 09:20 PM
pmibach
1983 - 2012 Ranger & B-Series
Apr 7, 2011 09:48 PM
jessel
May 29, 2009 10:20 AM
