Sponsored by: Real Truck
torquing lug nuts
Old Jan 2, 2004 | 12:53 PM
bkvanbek's Avatar
bkvanbek
torquing lug nuts
Can someone tell me what to torque the lug nuts to?
Old Jan 2, 2004 | 01:12 PM
Munkey's Avatar
Munkey
150 ft. lbs.
Don't over torque them or this will happen!
This is what happened to me when I over torqued the lug nuts by hand!!
Old Jan 2, 2004 | 02:32 PM
abendx's Avatar
abendx
nice pic munkey (ouch)... at least you have seven more to keep the wheel on
Old Jan 2, 2004 | 03:17 PM
cwb's Avatar
cwb
That's a $500 mistake. Owie!
Old Jan 2, 2004 | 03:40 PM
Munkey's Avatar
Munkey
$500 if I have the dealership do it for me. $24.60 and about 4 hours of my time if I do it!
Too busy right now, I'm not towing or hauling anything so it can wait a while.
Old Jan 2, 2004 | 03:59 PM
bkvanbek's Avatar
bkvanbek
Thanks for the quick reply. I am rotating the tires and I don't have access to a lift. I suppose I have to put all four wheels up (on jackstands) at same time to rotate the tires properly, don't I?
And does anyone know a good tool to get those factory lug covers off, without damageing them or the chrome wheels?
Old Jan 2, 2004 | 04:29 PM
Oneof6's Avatar
Oneof6
One thing to consider, you are supposed to lubricate the swivel washer on the lug nut, not the stud threads. When you lubricate the threads you increase the final torque by 1.4 to 1.6 of the tool output value. It is easy to overtorque a lubricated stud and break it off. Use a good torque wrench go 150 to 165 ft/lbs, dry threads you will be OK. I am 6'6" and weigh a petit 265 lbs, I have to watch it when I put that many grunt pounds on a hand 4-way.
Rotate the tires, I don't bother with that. I just run a set of tires to 40K and get another set. But I do pull the wheels, one at a time, about every 10K and inspect everything. When I do put the front end up, or the back end, I jack on the axles where the U-bolts attach, not the differential chunk. I had a service shop do that one time and I caught them, when I left they had a understanding of plain old English.
Old Jan 2, 2004 | 04:34 PM
soundmann's Avatar
soundmann
Would the lug nuts be difficult to loosen without an impact wrench (say, with a regular 4-way wrench) if the torque were 150 ft/lbs?
Old Jan 2, 2004 | 04:47 PM
Oneof6's Avatar
Oneof6
soundmann, not to me. I take my lugs off with a four-way. When I pull them off they are torqued to 165# and I break them loose real easy with a four-way.
Old Jan 2, 2004 | 05:29 PM
Outpost22's Avatar
Outpost22
Ditto on the above info (150 lbs and anti-sieze on the washer/nut).
Question- If you add anti sieze and it gets on the stud threads, should you remove the lube off of the threads? I didn't so far and it seems fine after 10 months (torque)
Old Jan 2, 2004 | 05:51 PM
99f350sd's Avatar
99f350sd
I havn't torqued any wheels in years. I just use my impact gun you kinda get a feel for it after awhile.. no problems
Munkey: That stud you broke if you look at the picture was fractured long b4 it broke. I know you are a beef cake but I don't think normally a person could break one.. LOL
I don't feel that with 8 studs its all that important to worry about torque. Anywhere between 120 and 160 should keep the wheel on. As far as warping as with 5 lug car rims I don't feel thats an issue here..
Dick
Old Jan 2, 2004 | 05:55 PM
Munkey's Avatar
Munkey
Good advice Oneof6, that is EXACTLY why I broke my stud off, it had been lubricated!
As far as getting the lug covers off, the best tool I've found is the stock tire jack!! I've used a big screwdriver wrapped in a shop towel, and it only marred the cover and dented the wheel.
Old Jan 2, 2004 | 06:01 PM
Oneof6's Avatar
Oneof6
Outpost22, I like accurate torque readings. Whenever I use lubricated threads a factor is involved. Course threads .6, fine threads .4 times the recommended dry torque. I have assembled large rotating elements in the power industry for over twenty years this is what works for accurate torque applications.
Old Jan 3, 2004 | 08:46 PM
g8rh8r's Avatar
g8rh8r
bkvanbek,
I'm not sure how the chrome wheel covers are set, but the cheap plastic ones on the steel wheels have little cut outs on them. The lug wrench under the hood is built to take them off at the end opposite the socket. Hope yours are set up this way too. By the way, when rotating the tires, I usually put jack stands in the front, and the jack under the axel in the back.
Old Jan 3, 2004 | 08:47 PM
g8rh8r's Avatar
g8rh8r
oneof6,
What kind of tires are you using, cause I'm only getting about 25,000 a set, and it's pissin me off.
Kountryguy
Jun 15, 2014 07:57 PM
rblaine9000
6.4L Power Stroke Diesel
Sep 6, 2011 01:04 PM
Dean M
Nov 14, 2004 04:32 PM
jacque_strap
1978 - 1996 Big Bronco
Aug 26, 2004 08:17 PM
jakegypsum
Apr 16, 2001 01:44 PM
