Sponsored by: Real Truck
Lug nut Torque
Old Jun 14, 2014 | 09:54 PM
Kountryguy's Avatar
Kountryguy
Lug nut Torque
Can anyone tell me what torque setting I should use for lug nuts on a 2000 F-350 dually? Thanks
Old Jun 14, 2014 | 10:36 PM
EXv10's Avatar
EXv10
Probably the same as the 4 tire trucks; 155 pounds.
Old Jun 14, 2014 | 11:51 PM
Frdtrkrul's Avatar
Frdtrkrul
150-165ft/lbs is what my car torque sheet says.
Old Jun 15, 2014 | 07:29 AM
projectSHO89's Avatar
projectSHO89
155 if unloaded, 165 if loaded. Check again at 100 and at 500 miles.
Old Jun 15, 2014 | 08:56 AM
EXv10's Avatar
EXv10
So you loosen and tighten them every time it is loaded and unloaded and then loosen and tighten again twice after each time? When do you you actually find time to drive it? What would Mark Twain say?
Old Jun 15, 2014 | 09:11 AM
Big-Foot's Avatar
Big-Foot
Remember guys - factory recommended torque settings are based on clean and dry (not lubricated) threads..
Old Jun 15, 2014 | 09:27 AM
EXv10's Avatar
EXv10
That goes for spark plugs too which is why some people lube the threads with anti-seize, choose a higher end torque figure, and then add a little because "more is better".
Old Jun 15, 2014 | 07:57 PM
projectSHO89
No, silly! It's based upon the truck's status at the time the wheels are installed. Read the service manual.
MIKEDENGINEER
Aug 13, 2014 10:57 AM
richccc
Feb 8, 2009 01:24 PM
Supercab
Mar 8, 2008 09:16 AM
joeycyph56
May 2, 2007 07:50 PM
damonlan
1997 - 2003 F150
Jan 18, 2003 11:36 PM
