Stuck Tailgate
Old Jan 1, 2004 | 11:47 PM
brt's Avatar
brt
Stuck Tailgate
The tailgate on my '92 F-150 won't open. It feels like the left side latch is the one hanging up. The handle also doesn't feel right. It does not have the spring action that it used to have. The problem that I have is that there is a cover over the inside of the tailgate and the cover's screws are covered when the tailgate is closed. There is also a metal cover over the edge with the screws covered. I've tried some gentle and not-so-gentle persusion methods with no success. Any suggestions would be appreciated
Old Jan 2, 2004 | 06:53 AM
rlp's Avatar
rlp
brt-
So you have an aftermarket inside tailgate cover protecting the inside tailgate? Metal or rubber??
One way or another you're going to have to "break in" through that cover to get to the access panel, then remove that (I think 8 or so Torx head screws).
From there you can manually work the control rods that run from the handle to each latch. Luckily for me I released my stuck tailgate that way, but the right latch kept jamming. I had to disassemble everything and remove and bend one of the tangs on the right latch, the replace the handle with the Help brand from parts store.
https://www.ford-trucks.com/forums/s...25252Btailgate
-rlp
Old Jan 8, 2004 | 02:27 PM
frdtrkman's Avatar
frdtrkman
I had a simiar problem with my 95. there are two yellow clips that hold the control rods to the handle. One of mine broke and would not release one side. I had to open the back and replace it. give that a check.
cub22908
Mar 18, 2017 03:10 PM
Deuce3301
Jan 4, 2017 06:38 PM
dwilliamsceg
Apr 6, 2016 09:30 AM
Fgodbout
Jan 22, 2016 07:26 AM
Mil1ion
52
Oct 4, 2006 03:20 PM
