Sponsored by: Real Truck
Electical Wiring Question
Old Oct 12, 2002 | 04:16 PM
OfficerLow's Avatar
OfficerLow
I have a 2002 F250 Lariat Crew Cab.
I'm trying to install a two way radio and needing to tap a wire for power. My first choice was to just go into the fuze box and squeeze the positive wire in with a fuze and ground the negative, but with the new smaller fuzes there isn't room to get the wire in with the fuze.
My next thought is to tap into the cigarette lighter power. I removed the dash panel with the silly hook thing next to the cigarette lighter to get to the wires. The cigarette lighter has 2 wires - a black one and a blue one with a white stripe. Which one of these is positive and which one is negative? I'd guess that black is negative, but I want to make sure instead of ruining my two way radio and/or truck.
Any better suggestions to tap power?
Thanks
Old Oct 12, 2002 | 05:07 PM
4x4x4x4's Avatar
4x4x4x4
There is a splitter type fuse holder available that plugs into a fuse location that you choose.I know that they are available for the standard size blade type fuses and I believe that they are also made for the smaller type also.Just about any auto parts store can fix you up.
Old Oct 12, 2002 | 09:31 PM
Quikirk's Avatar
Quikirk
Steve is correct. These are mini-fuse taps. They allow you to install a female stab connector right onto your mini-fuse. I've used them on my SD. They work nice and fit well into our fuse box panels.
Old Oct 13, 2002 | 07:47 PM
FortyFords's Avatar
FortyFords
The lb/wh is the + volts its 20 amp protected.
but as the guys said they make those clips that plug into the fuse
panel also
Rich
Old Oct 13, 2002 | 08:22 PM
Yeti's Avatar
Yeti
Webslinger
May 23, 2011 03:44 PM
ten70man
1997 - 2003 F150
Nov 11, 2010 12:12 AM
Philnamy
2004 - 2008 F150
Feb 28, 2008 09:09 PM
Jeff Grelson
Apr 10, 2005 06:03 AM
TallPaul
Electrical Systems/Wiring
Dec 28, 2002 11:28 PM
