Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Windshield Mirror Removal
Old Jan 4, 2004 | 09:08 PM
Andysutt's Avatar
Andysutt
The best way to remove it...
Try backing up all day long,
it will fall off
It always falls off when you need the mirror
Old Jan 16, 2004 | 09:06 AM
Wndsor's Avatar
Wndsor
i agree with mhg, use a heat gun or hairdryer on the OUTSIDE of the windshield to heat it, it will fall right off
Old Jan 17, 2004 | 01:02 PM
coatsbc's Avatar
coatsbc
The best glass adhesive is either Loctite 416 or 420 with 7113 accelerator.
Most off the shelf repair kits have a 6 mo. shelf life and are usually expired.
The 420 will hold 5 pounds within 30 sec.
Old Jan 21, 2004 | 10:47 PM
bgreen's Avatar
bgreen
I used to install windshields for speedy....tap the base of the mirror where it sits on the metal tab upwards with a deadblow hammer (plastic hammer) the mirror will slide up the tab as you tap it. If you want to remove the tab to relocate it higher or lower heat it up a little ( the tab itself not the windshield on the outside) and as someone mentioned twist and pull don't just pull. the best adhesive is locktite with the spray primer not the mixing epoxy, use the spray and glue sparingly and let it sit for 20 mins.make sure all the old glue is off both the w/s and the button and it should stick quite well. I hope this helps!
Old Jan 22, 2004 | 04:19 AM
MrOldV8's Avatar
MrOldV8
Originally posted by Tim Lamkin
Mine keeps falling off have bought the kits to glue back on (x4) and it never last past a day.
Kits are a POS or installer is an idiot…………hum
Tim,
Take it to a windshield shop. They'll probably glue it on for a couple of bucks.
Old Jan 22, 2004 | 07:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally posted by MROLDV8
Tim,
I have been so flustered with this I used super glue and it has not come off yet..........go figure
Old Jan 26, 2004 | 11:23 PM
ASPJ18's Avatar
ASPJ18
If a hairdryer or heat gun will loosen the tab, how come in the hot
summer sun it still stays on ?
Old Jan 27, 2004 | 07:34 AM
IB Tim's Avatar
IB Tim
magic
HKusp
Jun 18, 2015 11:34 AM
SFtoBoston
Mar 31, 2015 01:35 PM
dave3406
Apr 15, 2011 02:52 PM
lakerats
Oct 14, 2010 10:21 PM
PaulzF150
Sep 22, 2003 05:54 PM
