Any ideas how to remove the windshield mirror? Rather than having a standard set screw to hold it to the metal button (glued on the windshield), it has a metal clip that wraps around the whole assembly. I have tried prying the clip off, but am afraid to exhert too much force. How do I get the mirror off the metal mounting button?
Welcome to FTE. I have not seen one like that. It would seem that without a set screw it would be too loose. Maybe you could knock the whole works off with a block of wood and then look at it.
You need a very small screwdriver to get that off. Just push the point into the 1/8" slot and it will release the lock. Then, the mirror will slide up and off of the mounting pad.
Freight Train is right. However, it is a little awkward working on it while the tab is still attached to the windshield. It is really a spring that you need to pry up with the screwdriver blade. It holds the mirror to the tab with spring pressure, usually the end is seated into a dimple in the tab. If you want to remove the mirror with the tab attached, work a razor blade between the windshield and the tab while gently cutting through the adhesive. Key word here is gently.
I managed to borrow a shop manual...sometimes we look for complicated methods to do something easy....the manual says to place the mirror in the full down position and just snap it off the mount! SOunds too easy....watch me crack the darned windshield!
Originally posted by 78ranchero Scrape all adhesive off and clean with alcohol or carb cleaner. Use both parts of the kit and it should work. Make sure none of the surfaces are damp.
Have done that…the first, the second, the third…….and so on.
Have bought three different brands of kits, gone to extreme measures to make sure, all clean, all dry…..still the thing is on the floorboards or in my lap within 24 hours of installation.
Please don't try and just knock the mirror off the glass, you can end up with a big hole. If you need to take the tab and everything off, the prefered method is a twisting motion. Just kind of twist the thing CW or CCW - doesn't matter which. I grab it with a set of channels and give it a quick twist. That way I'm not pulling away from the glass, just breaking the glue between the tab and the glass.
Originally posted by 78ranchero Tim- That is odd. Maybe use another (new) metal tab and try a slightly different location on the ws and adjust the mirror so you can see out of it.
At this point, I would stand on my head in the corner and stack greasy BB’s if I thought it would help.
Originally posted by Tim Lamkin Have done that…the first, the second, the third…….and so on.
I used one of those kits on a previous vehicle and it held great. If I remember right, the instructions said to not mount the mirror on the tab for 24 hours to allow the epoxy to fully cure.
Originally posted by eehoepp I used one of those kits on a previous vehicle and it held great. If I remember right, the instructions said to not mount the mirror on the tab for 24 hours to allow the epoxy to fully cure.
Cheers,
Eric
One of the kits did say that..........tried that....
