Headlight Question
Old Dec 31, 2003 | 08:32 AM
LesPaul's Avatar
LesPaul
Headlight Question
My driver's side lowbeam went out. So I bought a new headlight and replaced it. Still is out.
It was getting dark so I went inside for the night. I'll start poking around at it again tomorrow (probably with a hangover).
Anything obvious that goes wrong, like a fusable link?
Thanks,
Frank
Old Dec 31, 2003 | 08:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
Bad ground connection.
Bad connector.
Does the high beam work correctly? If it does the ground is good.
Old Dec 31, 2003 | 09:22 AM
Sycostang67's Avatar
Sycostang67
Make sure the wires that go into the plug go all the way through to make connection with the prongs on the light
Old Dec 31, 2003 | 09:58 AM
LesPaul's Avatar
LesPaul
High beam works fine. Connector on.
Old Dec 31, 2003 | 12:21 PM
73Custom's Avatar
73Custom
Test for power at the plug with a test light. There should be 3 wires: 1 ground, 1 high beam and 1 low beam.
If you find power, then there is a bad connection or bad light. If no power then you need to trace the wire back until you find the break or loose connecton.
Marty
Old Dec 31, 2003 | 12:26 PM
olfordsnstone's Avatar
olfordsnstone
Take the light that works from the other side and plug it in. You never know, you may have purchased a faulty light. Probably wires and connection prob tho. Easy enough to rule out with a light swap.
tbugher62
Dec 16, 2013 07:21 AM
fastmover
Sep 18, 2007 05:35 AM
rpxr400
2004 - 2008 F150
Feb 3, 2007 06:08 AM
dirtjb18
Electrical Systems/Wiring
Jan 10, 2006 08:21 PM
rogue69
Jun 6, 2003 04:18 PM
