Sponsored by: Auxito
E4OD Shifting manually
Old Dec 30, 2003 | 02:39 PM
buckskin's Avatar
buckskin
Just did a fluid/filter change in truck. Went to shift through gears starting with Park going to low 1 and back while at idle. Couldn't/wouldn't shift to low 1. I took it for a test drive and left in drive. Seemed to shift through gears fine. Came to a stop and shifted all the way down manually. Coloumn on shifter read low 2. Shifted into drive at 2500rpm. When I did this rpm dropped to about 2000rpm and rose to about 2300rpm and shifted again. Had the OD turned off. Turned it on and shifted.
Can the rest of you shift into low 1 or is this just me?
Old Dec 31, 2003 | 01:05 AM
Racerguy's Avatar
Racerguy
Did it work ok before you did the fluid change?
Does the shifter physically go the whole way down into manual 1st? Last week I had one that wouldnt go past 2nd. There was a rock jammed in behind the shift lever on the transmission preventing the lever from moving the whole way.
Old Dec 31, 2003 | 08:45 AM
buckskin's Avatar
buckskin
Don't know if it worked before. Just bought the truck and trying to do some preventive maintance. Wouldn't of found problem if I han't read in one of the threads to shift through all gears after changing fluid. The shifter will not go all the way down into manual first. Will look around the shift lever on the tranny. Hope its as simple as that. Don't think it's anything to major or the tranny wouldn't shift right when left in drive. Thanks for the advice.
Old Dec 31, 2003 | 05:09 PM
buckskin's Avatar
buckskin
Your awesome Racerguy!!! All it was were a few small pebbles. Hope you have and extra good New Year.
Old Dec 31, 2003 | 05:20 PM
Racerguy's Avatar
Racerguy
Great that it was an easy fix
Happy New Year to you too.
3000gtman
45
Oct 21, 2016 08:57 AM
deputydog03
Mar 16, 2016 09:42 AM
UrMedic
Jan 21, 2016 07:12 AM
kper05
1997 - 2003 F150
May 27, 2012 03:45 PM
madmoose
1978 - 1996 Big Bronco
Oct 24, 2003 09:33 PM
