Softer ride
Old Dec 30, 2003 | 09:55 AM
bri's Avatar
bri
Softer ride
I know that the F350 is a 1 ton truck and will likely always ride pretty stiff.
However, does anyone know of a bolt on kit that will take away some of the harshness of driving, especially when unloaded?
Thanks in advance,
Brian
Old Dec 30, 2003 | 10:54 AM
Hope Springs Hauler's Avatar
Hope Springs Hauler
Acouple Hundred pounds in the bed helped mine but I also wanted to keep factory setup for mine.
You might be able to get custom springs made with more (thinner) leaves in the pack.
Old Dec 30, 2003 | 02:22 PM
Foneguy's Avatar
Foneguy
I've got a 1 ton Dually and this thing rides better than my buddies F-150 and there both the same year. I agree with HPH... some sand bags in the bed will give a little less jolt.
YMMV
Old Dec 30, 2003 | 08:28 PM
brwolfjr's Avatar
brwolfjr
how about some bilstein shocks. They made a huge difference on my truck.
Old Dec 30, 2003 | 08:52 PM
Strjock81's Avatar
Strjock81
My 99 rides a lot rougher than my buddy's 00, same exact truck...can't figure it out either...
Old Dec 30, 2003 | 09:19 PM
F0rdF0rever's Avatar
F0rdF0rever
I heard that airbags help alot. One of the places ive seen them are at www.jcw.com
Old Dec 30, 2003 | 09:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I have the Bilstein's. They do ride better, but they are not all that soft. I've heard good things about the velvet ride shackels.
Old Dec 31, 2003 | 08:15 AM
cangim's Avatar
cangim
Last truck was a F250 Light duty, looked like a half ton, it had factory air bags in the back, rode like a catty. Liked that setup a lot, automatically leveled the truck when you put a load in it. All the weight in that system rested on the air bags, had two leafs to keep the axle in line. Have been thinking about doing a similar setup on my 350 as well, Firestone makes bags that are rated to cary 5000lbs per set.
blsd49
Jun 20, 2013 03:43 PM
msuforeman
May 22, 2008 11:18 AM
Brian 2002
Nov 20, 2007 06:38 AM
Fomoko1
Jul 19, 2007 10:24 PM
bneafus
Jan 26, 2007 08:52 AM
