Sponsored by: Real Truck
Dana 60
Old Aug 31, 2002 | 12:08 PM
Bobbylee's Avatar
Bobbylee
Dana 60
Could someone Please tell how to get out the king pins so I can
change the seals on a Dana 60 4x4? Maybe a diagram or 2 HA,HA.
Right front is leaking bad with only 40,000 mi on it. By the way
I would not recommend Mills Ford on Lincoln in Anh. to anyone
for anything. Not very nice people. I thought it was a Dana 50 but
I think I was wrong. It's a 98 axel in a 99 F250 Super Duty truck. Any ideas?
Thanks, Bobbylee
Old Sep 1, 2002 | 11:15 PM
rheaman's Avatar
rheaman
Dana 60
You probably don't need to change the kingpins. Four bolts hold in the top bushing. It is a nylon bushing with a spring. Replace the bushing. Lower is held in also with . . four bolts? and it is a bearing. Replace the bearing. Should you need to actually change the kingpin itself you will need to take it to a shop. Takes a very large impact wrench to get them out and back in.
I don't know what year your truck is, maybe not all are the same. This is how mine is. Hope it helped some.
2k1 superduty psd 6 speed, gibson extreme dual exhaust, acetone emblems, reese brake controller, white knight backup lights, 2001 bullitt mustang fuel door, painted grill, bedslide, leer 100r cap, bedrug, suvlights wiring, 85/100 watt xeon bulbs . . its endless
Old Oct 19, 2002 | 07:01 PM
gary3des's Avatar
gary3des
Dana 60
I'm also trying to replace the king pins on my Dana 60. Poking around a bit I saw an article that talked about a 7/8 hex tool costing over $50 and a long bar to break the 700 foot pounds to get it off.
I already bought the king pins along with the plastic busing and bearing for the lower king pin and every thing I to rebuild the front end. I'm intent on getting the king pins out and am struggling to find a place to get that 7/8 hex tool with the 3/4" drive that can take 700 foot pounds. I already own a 3/4" drive set so I just need that hex tool. I'd also like to figure out where to get a torque wrench that can go that high.
If you or any one has any good places to get one I'd appreciate it.
Old Oct 19, 2002 | 08:33 PM
DVD Nimrod's Avatar
DVD Nimrod
Dana 60
Flip4ford
Kansas Chapter
Dec 7, 2012 09:18 PM
sledge1992
56
May 26, 2011 01:45 PM
tiopet
Jul 17, 2009 03:32 AM
kristie
Offroad & 4x4
17
Feb 14, 2009 12:03 PM
big_red_79
May 30, 2003 12:37 PM
