Sponsored by: Real Truck
brake problem, HELP
Old Oct 18, 2002 | 04:50 PM
Muleskinner's Avatar
Muleskinner
brake problem, HELP
Old Oct 20, 2002 | 04:35 PM
thunderbritches's Avatar
thunderbritches
brake problem, HELP
Have a 99 superduty powerstroke. Replaced brake pads of front
of truck. Pads had normal wear, nothing serious. I have done this
hundreds of times so I'm a beginner. I left the system closed,
used C-clamps to compress calipers. Since changing pads the truck
pulls to the right when I hit the brakes. Its bad enough that I got
to do something about it. Have gone over and over trying to figure
out what I've done wrong. Have bled the system at the calipers,front
and back. Have replaced both brake hoses from tubing to caliper. Had the right rotor turned. Have had both calipers off several times and]
see nothing wrong. Any suggestion? Thanks
Old Oct 20, 2002 | 06:43 PM
BlueKnight's Avatar
BlueKnight
brake problem, HELP
Have you checked the piston in both calipers? sounds like one of them may be hung up check the left side, Maybe the caliper slides need lubed.
Old Oct 20, 2002 | 07:48 PM
thunderbritches
brake problem, HELP
Thanks for your input Blueknight. I'm focusing
on the left caliper, the slide is clean and smooth
can not believe that is the problem. I pulled left
caliper, pressed the brake pedal, have good travel
on both pistons but have no way of knowing the amount
of force being applied. Ordered a new caliper today
should be here Tues. Hope that solves the problem
but have my doubts. Brakes were working fine before
I replaced the pads so what the heck did I do to cause
this malfunction? Thanks
Old Oct 20, 2002 | 11:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
brake problem, HELP
I have heard of shaving down the pads on the offending side will eleviate this condiiton.
I'd do that before I plunked down my hard earned cash for a new caliper!
Old Oct 21, 2002 | 07:05 AM
FortyFords's Avatar
FortyFords
brake problem, HELP
I had this happen once on an explorer,hence what my problem was,
the rotor was glazed and the new pads just couldn't get a bite.
had them both turned an problem went away.But now i take some medium grit sand paper and scuf them up before installing new pads ,this after doing a rotor runout chk of course,looking for warpage.
(dial indicator)
Just another thought on your procedure you may have caused an unbalanced situation by pushing back on the caliper pistons with out releasing the
bleeder screw to drain of the pressure.
have you tried bleeding as decribed in the manual for abs brakes?
some special procedure
also if you get to much force invovled in pushing back the pistons you can dislodge the o-rings inside
so the piston doesn't return as smoothly.
Just a couple thoughts
Rich
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
