Sponsored by: Real Truck
2003 350 SD
Old Oct 18, 2002 | 12:57 PM
Bruker's Avatar
Bruker
2003 350 SD
I'm a member of a local Volunteer Fire Dept. and we just placed an order for an F-350 4x4 CrewCab with the new 6.0 PS and 5spd auto. This truck will be converted to a "grass" truck with addition of a 200gal. tank and pump. The truck will also be used for personel transport for mutual aid runs and it will also be used to pull an enclosed utility trailer.
Old Oct 18, 2002 | 04:50 PM
Muleskinner's Avatar
Muleskinner
2003 350 SD
Where do you live?
Old Oct 18, 2002 | 07:46 PM
Kurts50's Avatar
Kurts50
2003 350 SD
Is it a dually? I would assume so because of the extra weight in back. What kind of rear end..a 4:30?
Old Oct 18, 2002 | 09:39 PM
sbinsdca's Avatar
sbinsdca
2003 350 SD
Question..comment:
I've looked at different configurations of the 250/350 and it seems that the only rear end configuration that can be ordered is the limited slip 3.73 with the PSD and the 5 speed auto tranny
Bud
Old Oct 20, 2002 | 08:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
2003 350 SD
You can get a 4.10 axle with a dual rear wheel F350. The 3.73 is standard.
Old Oct 21, 2002 | 07:18 AM
Bruker's Avatar
Bruker
2003 350 SD
We're located in West Central Ohio. No, it's not a dually because it will get off-road and when mud gets packed between duals you get two big "slicks" back their. We ordered the 3.73 LS.
Old Oct 21, 2002 | 07:38 AM
Mark Kovalsky
2003 350 SD
