93 Explorer stalling
Old Dec 29, 2003 | 08:06 AM
Homaler's Avatar
Homaler
Hi
I just purchased a 1995 Explorer with 4.0 6.
The vehicle seems to be “underpowered” and stalls intermittently at stops and turns.
Have replaced mass flow sensor and previous owner appears to have replaced most if not all sensors
Fuel system is proper pressure, replaced all filters
Computer shows “everything OK’
Help
Please reply to homaler@aol.com
Old Dec 29, 2003 | 08:25 AM
Opera House Works's Avatar
Opera House Works
It still may be fuel pressure
Some fuel pressure regulators with a lot of miles can wear a bevel on one side of the seat. This is caused by long term wear from a slightly off center spring. At high vacuum conditions, like idle, the valve slips to the side and sticks open. Measure the pressure when it isn't stuck and it is just fine. Had that problem with my 92 at stoplights and always at the same highway turn. Only found it by substitution and cutting the pld one open. If you have exhausted other possibilities, I would change it.
mikedubrow
Modular V10 (6.8l)
Jul 6, 2007 10:22 PM
whiteaddiction
Apr 7, 2007 08:32 AM
yoeman
Nov 1, 2006 12:21 AM
zypr
Apr 3, 2003 04:02 PM
sdamman
Feb 4, 2002 02:15 PM
