rough idle - compressor clutch
Old Dec 28, 2003 | 12:48 AM
kiwi98j's Avatar
kiwi98j
My `97 explorer 4.0 v-6 has developed a rough idle (500 - 900 rpm) that modulates with the engagement of the ac clutch. Clutch engages for 4-5 seconds then dis-engages for a 4-5 seconds. Cycling continues until temp switch is set to off or ac. With either ac or off selected, cycling stops and idle smoothes out to about 8-900. Anyone seen this before?
Old Dec 28, 2003 | 09:01 AM
sosotwo's Avatar
sosotwo
my 96 does the same thing ac is not even on and the clutch opens and closes till the engine warms up then it stops
don't have a clue what it is
Old Dec 29, 2003 | 08:40 AM
Opera House Works's Avatar
Opera House Works
The AC even works on defrost
To eliminate possible compresor problems, disconnect the electrical connector that goes to the electrical compressor clutch. Just follow the wire.
