Will Not Start
Old Dec 29, 2003 | 06:32 AM
bradd's Avatar
bradd
Unhappy Will Not Start
I have a 2001 Supercrew (5.4L). When I attempted to start it on Christmas morning - NOTHING! Will not turn over, click, or anything. No luck jumping it off. Seems to have good battery power (all lights, chimes, radio works, etc..) Tried different key thinking that it may be the antitheft - no luck!
Any suggestions?
Old Dec 30, 2003 | 01:28 AM
hood's Avatar
hood
Sounds like your starter was somehow cut out of the system. Check fuse #21 (15A). It's description: Starter Relay. This is found in the passenger compartment fuse panel.
Also look at Maxi Fuse #111 (40A) found in the power distribution box. It's description is: Ignition Switch Battery Feed (start and run circuits).
The above fuse info is from my 02 owners manual....yours should be the same.
Good luck, hope you find it to be something as easy as a blown fuse.
-hooD
Old Dec 30, 2003 | 12:47 PM
bradd's Avatar
bradd
Turned out to be the starter relay!
06silvercrew
North Carolina Chapter
57
Jul 30, 2010 07:30 PM
Stroker09
Jul 31, 2008 10:07 AM
sammer4u
2004 - 2008 F150
Nov 14, 2007 08:35 AM
jawmaw
15
Dec 30, 2006 10:06 PM
Diesel Tech 27
Jul 28, 2006 05:17 PM
