I have a chance to pick one up. The block came out of a Lightning, and I was wondering if it will fit in the Expy. The description is a Lightning Long Block.
huh? Long block, short block, small block? Well anyway, to answer your question, yes it will fit. It is still the 5.4L I would pick it up in a heartbeat and build a BAM for your truck. With the lightning heads, and the blower. Then light up all 4 tires, and smoke some ricers. Wow, was I typing my dreams out again?
Well, as it turns out, it's just the Lightning block with all the components, which makes it a long block. Just the bare block would make it a short block.
I got confused with Big and Small block. I think I'm going to get it.
I wouldn't pay any extra for a Lightning long block over an Expedition long block. The Lightning engine has lower compression (8.4:1 -vs- 9:1) so you will drop in power. The pistons are not forged, neither are the rods or crank (although I have heard a few got forged cranks). In general there is NO improvement for just running the Lightning block.
The heads are exactly the same also (PI Heads). The cams are not even different!
don't pay extra just because it was from a Lightning!
It is my understanding that the Lightnings have all forged internals. I have looked into the Lightning crate engine for one of my boats. I'm pretty sure they have forged crank, rods and pistons.
Here's the list of what my future block will come with:
Mod Max 4340 balanced H Beam rods with ARP 2000 cap screws-
Mod Max 3.552" +.05 Plasma Moly File-to fit Rings 1.5/1.5/3mm. Boosted Racing and Street Perf.
Federal Mogul Main Bearing
Federal Mogul Rod bearing
I have the Mod Max rods in my Navigator with Probe pistons and the factory Forged Navigator crank. For rings I ran a custom set of Total Seal gapless top rings. I need to get to the dyno still but I am hoping for 400 RWHP and 450 RWTQ.
If you've got a chance to grab a Lightning longblock for a real decent price grab it.Around here by me a bare block is a bare block,a short block has the crank,rods and pistons installed in the block,but no heads,(and cam in a pushrod motor).A long block has everything the short block has and also has the heads installed.
