Offroad & 4x4
TTB 44 diff cover idea
Old Dec 28, 2003 | 08:16 PM
hoxiii's Avatar
hoxiii
I was wondering if anyone had tried this: You take a TTB 44 center section and start studs into the bolt holes. You then take the DS TTB arm and cut just inside the bolt pattern for the diff all the way around and throw that piece of metal away. Then take the center section with the studs and put them through the bolt holes. Then use a regular 44 diff cover, put it over the studs from the other side of the arm, and then use nuts to fasten it all together. That way you'd have easy diff inspection and easy axle replacement if you had to get to the C clip on the PS stub axle. Just an idea, but what is everyone elses' thought on this?
Justin
Old Dec 28, 2003 | 11:42 PM
Ryan50hrl's Avatar
Ryan50hrl
I wouldn't recomend doing this. The rigidity of your axle housing is relying on that piece of metal to be there. Whats going to happen if you take that out is that you've effectivly removed all the strength from your axle. It would be like cutting the center section out of your rear axle, and using muffler clamps to hold the tubes in. It will not only leak and bend, but be unsafe. DO NOT DO THIS.
Old Dec 28, 2003 | 11:54 PM
fishmanndotcom's Avatar
fishmanndotcom
i think it would be easier to swap in a dana 44 monobeam...easy access and a lil stronger!
-jason-
Old Dec 29, 2003 | 10:25 AM
hoxiii's Avatar
hoxiii
I was figuring it was going to be something along the lines of that being a structural part, but had to ask any way.
Justin
Old Dec 29, 2003 | 05:56 PM
82F100SWB's Avatar
82F100SWB
It's a structural part, and henceforth, if you cut it out on the outside of the bolt pattern, it makes a nice, nearly indestructable cover for a standard D44... LOL
Old Dec 29, 2003 | 10:03 PM
85351ho's Avatar
85351ho
thats good thinkin
9.ford.5
Offroad & 4x4
144
Jan 15, 2022 07:25 AM
Bern_F150_4x4
May 16, 2009 01:19 PM
TallGuy_Az
Offroad & 4x4
Dec 29, 2004 02:19 PM
hoxiii
Offroad & 4x4
Sep 17, 2004 01:17 PM
