1978 - 1996 Big Bronco
Tailgate Window Motor Removal
Old Dec 28, 2003 | 05:32 PM
86BigBronco's Avatar
86BigBronco
I did a search but still have no answer..How the heck do you get the motor out i can't get the window down anyone know of a techy anywhere on this?
Thankyou.
Old Dec 28, 2003 | 05:44 PM
3broncocrazy's Avatar
3broncocrazy
i wonder why the search didn't come up with anything..........here is what came up when i searched. Should help you.
https://www.ford-trucks.com/forums/s...by=&sortorder=
Old Dec 28, 2003 | 06:03 PM
86BigBronco
Thankyou
Old Dec 28, 2003 | 06:12 PM
3broncocrazy
just let us know if you need more help - i work for beer
Old Dec 28, 2003 | 06:16 PM
86BigBronco
LOL..Ok.
Well it is still kinda of confusing..Some say you don't have to put the gate down some say you do But i will get it figured out..
Thanx for your help..
Old Dec 28, 2003 | 06:21 PM
3broncocrazy
Never done it with the tailgate up.......i would think it would be very difficult because where the access panel is.
Old Dec 28, 2003 | 06:25 PM
86BigBronco
Yeah..
I had both the door motor's out today repaired one replaced the other but when i got to the tailgate i could see the motor but had no idea on removing it..How would you get the window down if the motor is locked up?Would you need to remove the top?
Thankyou for your help..
Old Dec 28, 2003 | 06:30 PM
3broncocrazy
I hope you have already applied power to the motor.......only two wires come off of it and sometimes the safety swich could be bad or the gate not closed all the way.
You can remove the nuts on the brackets that are connected to the regulator to move the glass freely. Some yr gate have rivets insted of nuts........
These might be helpful:
http://ylobronc.users.superford.org/.../tailgate.html
http://rfr.htmlplanet.com/bronco/jou...al_page07.html
Old Dec 28, 2003 | 06:36 PM
86BigBronco
With a meter i am getting 12volt's to the motor the passenger side door motor was rusted beyond repair on the contact's themselve's and the inner casing of the motor..I can only assume that the same is with this tailgate motor the truck took a bath in a lake for about a week around 3 year's ago and has been parked every since everything is rusted everything...But the frame is unusualy good shape for an 86..The driver's side window motor appeared to have small river rock's in it not sure how they made it thru the sealed casing
Old Dec 28, 2003 | 06:38 PM
3broncocrazy
On edit i posted two links that might be of some help.......not telling you what to do, but i would still try power direct to the motor........Good luck
Old Dec 28, 2003 | 06:50 PM
86BigBronco
Thankyou for the advice..I will try direct power just as soon as i can get the motor out..I appreciate all your time and help...
Old Dec 28, 2003 | 06:56 PM
3broncocrazy
anytime......just forgot to stress with the gate open make sure you support the glass on something when you slide it out to work on the motor..... I've heard a few have broke glass - not good.
It's not that hard except the small area to work in.........
bronco6767
Apr 15, 2016 10:20 PM
6 or 10
Aug 24, 2015 08:02 PM
Welder7018
Jul 24, 2015 06:06 PM
7.3RP
May 11, 2015 11:09 PM
knabjordan
Aerostar
Mar 11, 2006 12:53 AM
