gastank problem
Old Dec 28, 2003 | 04:02 PM
FordFadgeole's Avatar
FordFadgeole
gastank problem
My 58 sat for 20 plus years. its got that syrup type crap inside from gas gone bad .Is there somekind of solvent i could put in it to break this up to flush it out or should i just replace the tank? thanks.
Old Dec 28, 2003 | 05:01 PM
gtkane's Avatar
gtkane
I had the same problem with my '56 and I tried everything from solvents to detergents even hot water-nothing worked.
I ended up getting another tank.
Graham
Old Dec 28, 2003 | 05:15 PM
FordFadgeole
Yea,i kind of thought along that way,i was trying to keep everything the way it was but a tank replacement wouldn't change much i guess. thanks
Old Dec 28, 2003 | 07:30 PM
JCPSME's Avatar
JCPSME
You might try a radiator shop. I've had a couple of tanks cleaned that way and it didn't cost much. Maybe 20 bucks last time.
Old Dec 28, 2003 | 10:09 PM
F250Rob's Avatar
F250Rob
I also struggled with a crappy tank for awhile and finally gave up. Found a good used one in a 56 F-600 dump truck at a wrecking yard for $80.
Old Dec 29, 2003 | 12:32 AM
laynrubber's Avatar
laynrubber
I have cleaned out old gas varnish by using MEK and sloshing the tank around. It's bad stuff but it worked.
Old Dec 29, 2003 | 07:51 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Took mine to a radiator shop where they boiled it out and put a sealer in it...It was cheaper than buying a new tank.
Old Dec 29, 2003 | 08:04 AM
pootscratch's Avatar
pootscratch
I also took mine to a radiator shop. They boiled it out and sealed it. Cost me about $100. I cleaned it out myself a few years ago, but condensation took over, and the tank started to rust and flake off. Since the sealing, I haven't had any problems with dirt or crap in my filter!! Well worth it!
Vern
Old Dec 29, 2003 | 08:22 AM
GreatNorthWoods
Hey Vern,
There ain't room for two Verns on this here forum...know what I mean, Vern? Meet me in street at high noon or get the hell outta town!
Of course, I'm just kidding. Glad to have another Vern on here besides me to kick around...
Old Dec 29, 2003 | 11:56 AM
FordFadgeole
learn something new every day. never thought of a radiator shop.thanks
Old Dec 29, 2003 | 12:05 PM
Jag Red 54's Avatar
Jag Red 54
Wow! Vern has a stunt double for the really risky topics. LOL, Welcome aboard. John
Old Dec 29, 2003 | 12:12 PM
fatfords's Avatar
fatfords
fordfaggiole,
If you are set on doing it yourself, I used lacquer thinner and a handfull of screws to do an ATVtank that had that sticky crud in it. I put about a half a quart in the tank with the screws and shook it until I thought my arms would fall off. I drained it and repeated the process with metal etch in place of lacquer thinner. Flushed it with water several times and then I used some left over gas tank sealer. The radiator shop sounds like a good choice too.
Good Luck,
Old Dec 31, 2003 | 02:01 PM
jeffh's Avatar
jeffh
While you're at it, don't forget to clean out or replace the gas line, too...
Old Dec 31, 2003 | 05:06 PM
FordFadgeole
Thanks guys.This truck sat for a long time so everything gummed up.haven't even got to the brakes yet.lol.I'll have lots of beginner questions through the winter.i,m trying to organize all this info before i start this spring.
Old Jan 5, 2004 | 08:56 AM
Jag Red 54's Avatar
Jag Red 54
Just an after thought, in earlier posts, from 2003, other home fixers reported using a length of heavy chain in the tank to break the muck up. Good luck, John
