Sponsored by: Real Truck
Aftermarket Reverse lights
Old Dec 28, 2003 | 03:15 PM
NHSuperduty's Avatar
NHSuperduty
I got a set of lights for Christmas. I want to install them like backup lights but I don't know wich wire is the reverse light wire.
I tryed to do a search but ended up more confused than I already am.
Any help would be apreciated.
2003 Superduty incase it helps.
Rich
Old Dec 28, 2003 | 05:18 PM
brwolfjr's Avatar
brwolfjr
check your 7 wire hookup for your trailer harness
Old Dec 29, 2003 | 03:12 AM
fitter565's Avatar
fitter565
I just did this to my truck today, On your 7 pin trailer harness the center pin is your backup lights, I believe the wire is brown with a black stripe. Look to make sure. I drilled and tapped the bottom of my reciever and mounted the lights there. The lights are tucked up under the bumper and out of harms way. I put the truck into reverse and its like having headlights in the back of the truck Hope this helps
Fitter
Old Dec 29, 2003 | 06:27 AM
jdadamsjr's Avatar
jdadamsjr
Pulling the rear light enclosure takes about 2 mins for 4 screws..
LOTS of room in there and up to there, so I just made my tap IN the light enclosure by running the wire up to there...
Old Dec 29, 2003 | 09:59 AM
NuDog's Avatar
NuDog
Curious if you ran relay set up or just tapped into trailer harness?
Was debating if relay and power was needed if tapping into trailer harness, I sort of figuring the wiring to the trailer harness would handle the extra reverse lights.
Thanks
Old Dec 29, 2003 | 10:54 AM
NHSuperduty
Thanks guys, I probably will tackle the lights next weekend.
Again thanks for the wiring help.
Rich
Old Dec 29, 2003 | 11:16 AM
DS02F250's Avatar
DS02F250
...and thanks from me, too. I am the WORST at electrical, so all this information REALLY helps as I draw nearer to getting some backup lights.
Old Dec 29, 2003 | 05:46 PM
brwolfjr's Avatar
brwolfjr
plenty of power of of the trailer harness. Besides, how long do you leave your truck in reverse?
Old Dec 30, 2003 | 03:28 AM
fitter565's Avatar
fitter565
Let us know how you like them? Mines like having headlights on back there..lol
Fitter
Old Dec 30, 2003 | 05:18 AM
NHSuperduty
Yeah I will post on how I like them. would get pics, if the wife shows me how to use the digital camera.
Also gotta get over a cold that I got. I am the biggest baby when i get sick.
Old Dec 30, 2003 | 08:28 AM
rmilchman's Avatar
rmilchman
I was thininig of using a relay, this way I could also turn the lights on from a dash switch. Would come in handy when hooking up a trailer.
Old Dec 30, 2003 | 02:21 PM
Crownie1's Avatar
Crownie1
I just put a set of driving lights on my rear bumper where the holes are drilled from the factory. I installed a switch panel and ran the wires to it as I have other lights on the front. The rear lights look slick. Already have had some comments on them.
Good luck!!
Old Dec 30, 2003 | 05:19 PM
Bowcop's Avatar
Bowcop
I already have the lights mounted to the rear with a switch on the dash. Could I also run a jumper wire from the + wire on the lights to the middle wire on the hitch plug. Would I have to install a relay to accomplish this? Thanks!
Old Dec 30, 2003 | 06:53 PM
rmilchman's Avatar
rmilchman
You most likely would not need a relay. I'm just in the habit of using one so I can run smaller wire behind the dash.
ttam31
All Things Towing
Feb 12, 2018 11:28 AM
RussF350
Feb 9, 2011 03:59 PM
TIKT B8
Jun 17, 2010 12:37 PM
01redcrew
2004 - 2008 F150
24
Feb 5, 2008 03:20 PM
PETE'S_6.0PSD
22
Nov 15, 2007 04:55 PM
