cooling problems
Old Dec 28, 2003 | 12:00 PM
hjohn29's Avatar
hjohn29
Angry cooling problems
I have a 69 f100 with 390/c6. I bought the truck in already running; therefore, I do not know whats inside the engine. It has a elderbrock manifold and mallory elect. ignition. The problem is with a thermastat installed it builds up pressure swelling the upper hose. Once it burst radiator, I replaced it and all the hoses installed a fan shroud and then the heater core burst. The truck runs fine with no thermastat, with the 190 degree it runs warm and is hard to start after driving awhile, it also clatters when shutting it off. With the 160 degree it runs fine but does not get hot enough to provide heat. I have not tried a 180 degree thermastat but with any thermastat it builds pressure. Any help will be greatly appreciated.
Old Dec 28, 2003 | 12:26 PM
sparky's Avatar
sparky
Ok I have to ask is it possible the thermostat is installed backwards???????
It will eventually open but boy will the higher temp ones ever build up pressure
Old Dec 28, 2003 | 01:36 PM
FTE Ken's Avatar
FTE Ken
Sounds like they're backwards to me. There should be no problems with over-pressure if its properly installed. If your truck isn't running correctly, or running too hot with a standard thermostat you have a fuel system problem.
Old Dec 28, 2003 | 08:20 PM
hjohn29's Avatar
hjohn29
I made sure that the tstat. was installed correctly. This is the 2nd 69 with a 390 that i've had. Yes, I do have a fuel problem, the fuel tank has rust inside I cleaned it with muratic acid but the rust has come back. I need to have it sealed, I think.
Old Dec 29, 2003 | 04:12 PM
Merlin68F-100's Avatar
Merlin68F-100
A new radiator cap would only set you back a few bucks. Yours may not be popping at the desired PSI. Just my $0.02
Old Dec 30, 2003 | 08:31 AM
talisker's Avatar
talisker
I agree about the radiator cap. If it was popping at the right temp then you should not swell the hoses etc even if the engine was overheating. You would just blow coolent overboard. It may be a combination of thermostat and cap.
Old Dec 31, 2003 | 06:15 AM
jds1971's Avatar
jds1971
It sounds to me like you have a blown head gasket. Even with the t-stat installed backwards (if it was) it still wouldn't build enough pressure to start blowing hoses and heater cores.
Start with a cold engine and remove the radiator cap. Make sure the radiator is filled to the top. Start the engine and look for bubbles coming up to the radiator filler neck.
Good Luck-
Joe
