oil pressure gauge doesn't work
Old Dec 27, 2003 | 07:27 PM
FordPickMeUp's Avatar
FordPickMeUp
on my 95 250 the oil gauge has been broke for the past year or so.The needle is stuck all the way over to the right as far as it can go.A guy at a shop told me the only way to fix it is to drop the oil pan.Is he right is this what i have to do or is there an easier way?
Old Dec 27, 2003 | 07:32 PM
Mil1ion's Avatar
Mil1ion
No,
There is a "Sending Unit" that is attached on the outside of the engine, with a wire that runs to the dash, via a wiring harness.
Old Dec 27, 2003 | 07:37 PM
Franklin2's Avatar
Franklin2
What engine do you have? The 302 and 351w sending units are near the front driver's side, down low near the oil filter.
Old Dec 27, 2003 | 07:50 PM
FordPickMeUp
i have a 351w what should i look for to fix it?i want to fix it as soon as possible.
Old Dec 28, 2003 | 06:29 PM
Franklin2's Avatar
Franklin2
It will look like a small metal can with a wire coming out of the middle of it.
Old Sep 15, 2004 | 12:40 PM
gatesj's Avatar
gatesj
His '92 probably has the smaller switch, about the size of a big spark plug.
Pegged towards high means a ground either in the sender or the line from the sender to the gauge.
ChristopherN
24
Aug 13, 2011 09:32 PM
mojo79
Nov 15, 2010 07:16 PM
jeremy53402
17
Aug 7, 2008 08:18 PM
eltakko
Jul 24, 2006 12:53 PM
rebel_ford4x4
24
Oct 23, 2004 09:26 AM
