my oops
Old Dec 27, 2003 | 06:30 PM
1960f-100-I6's Avatar
1960f-100-I6
Angry my oops
Where do I begin? I was conned into buying the pickup when I was nine, otherwise I might not have done it. Afew years ago I hated it, mainly because I hadent touched it and the project seemed impossible. This summer, 8 years later (yes I'm a youngin-17) decided to pull out the six and drop in an 8cyl-351. Boy was that a mistake, I yanked out the six and set in the eight. After much hassle with the mounts (and removing those rivits from the tranny mount with the torch-n-chisel method. Yeah do not even try to get any of those rivits off with anything. I ate up a $400 air chisle in the process)I decided to put the six back in about a week ago. Well the pickup's front end is in pieces and bolts are missing. You know how that goes. Anyway it has been one big headache so far but I think it will be worth it.(I hope anyway)
Old Dec 27, 2003 | 08:24 PM
barry's Avatar
barry
Yes, when you update to newer engines, etc.., be prepared for unforseen problems. it's part of the game. I myself prefer leaving them as they came from the factory, but there's others who want more. To each his own. The number one word is "Patience". It doesn't happen over night! Form a game plan as to what you want to do and do it one step at a time. You will make mistakes, everyone does. learn from them and go on. Take pics of before and after on what you do. It will help in re-assembly and give you a sense of pride and accomplishment. Don't worry about your age, I started in high school (16) on my first project, a 65 Mustang. Go for it and have fun!!
Barry
Old Dec 27, 2003 | 09:55 PM
1960f-100-I6
Thanks Berry
Thank you Barry for your re-assurance. I do believe that this project will take alot of time and effort. I should have thought it through before I went with the swap. But hey things happen dont they. So how was the Mustang? And what are you building now?
Old Dec 27, 2003 | 11:55 PM
55 F-100 PAUL's Avatar
55 F-100 PAUL
I too am 17 and am just starting my 55 f-100 project and its a bit overwelming but in the end I know it will be worth it. Instead of using a air chisle for the rivets next time you might want to just grind the head off the rivet off. Any way good luck with your truck!
Old Dec 28, 2003 | 07:48 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I found the best way to remove the rivets when I removed my crossmember was with a 5 lb sledge hammer and a hand chisel. Most of the rivets are not accessable with a grinder anyway.
Old Dec 28, 2003 | 07:53 AM
barry's Avatar
barry
My first Mustang was a 64-1/2 convertible. Wish I had it now! I went thru 6 mustangs before they got to rich for my blood. I'm now doing a 50 Ford F-1 pickup, all stock. This one will take the longest of anything I've owned. I've owned it about 15 years and at the rate I'm going, it will be another 15 years!!
Barry
Old Dec 28, 2003 | 11:33 AM
1960f-100-I6
55 F-100 PAUL
I did use the grinder. Thoes things would not come off with anything but the fire power.
GreatNorthWoods
How did you get enough swinging room for the sledge? did you take the body off? because i still had the cab on which minimized room.
Old Dec 29, 2003 | 06:44 AM
GreatNorthWoods
Originally posted by 1960f-100-I6
55 F-100 PAUL
GreatNorthWoods
Nope, did it body on. I just jacked it up as high as I could get it and swung away from underneath. It only took me about half a day...
