Sponsored by: Real Truck
Daytime Running Lights
Old Oct 30, 2002 | 05:56 PM
69_bronco's Avatar
69_bronco
After deciding that I didn't want to pay the dealer $350 to install the DRL,since they wouldn't let me order the truck with them,(fleet order only). I ordered the parts needed for about $60. The problem you ask? I can't find the plug for the relay that is supposed to be behind the glove box.The one behind the headlight is there in plain sight.My manual says it's there, but I haven't found it yet. Does anyone know where it might be hiding?
Thanks,
Old Oct 30, 2002 | 06:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
I'll look when I get home but I cannot help but to ask...Why would you spend $60 when all you have to do is reach over and turn the switch??
Old Oct 30, 2002 | 07:48 PM
69_bronco's Avatar
69_bronco
Well, I make 3-4 trips a year between my home in the east bay to our vacation/retirement place in Coeure d' Alene, and about half the trip is on two lane roads, and I don't want all the lights on the truck and 5th wheel burning for the whole 20 hour trip. This way I don't need to turn the lights on and off everytime We stop for gas or to eat. Yeah, I know it's lazy, but more convenient...
Old Oct 30, 2002 | 08:07 PM
No1Hookman's Avatar
No1Hookman
Maybe, if your truck is a late '01, the plug may be between the battery and the master clinder on the left side. My '02 had the plug in this position. It is a very early unit. Just a thought. If it would happen to be there, the relay you have won't work. Been there, done that.
Good Luck, Mark
Old Oct 30, 2002 | 08:27 PM
FortyFords's Avatar
FortyFords
look under the master cylinder on the plastic fenderwell this is where it is on 02
Rich
Old Oct 30, 2002 | 11:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
Makes sense to me!
Understnad though that I am personally against DRLs on cars & trucks. You see, I spend a lot of time on a motorcycle and I NEED the advantage of my lights (duals on high beam). Too many lights on the road and I'll just end up blending in and someone is going to do the left-hander into me.
Old Oct 31, 2002 | 10:13 AM
Waxy's Avatar
Waxy
Daytime Running Lights are the law in Canada. Apparently they reduce accidents and increase visibilty by some big number. I have to admit, they do make vehicles a lot easier to see in some situations.
I found this thread kinda funny because here, guys are always trying to find a way to disable their DRLs. They can be a real pain if you're hunting. They're also a pain in the kazoo if you want to park and idle your vehicle for a while without attracting any unwanted attention.
Waxy
Old Oct 31, 2002 | 04:23 PM
69_bronco's Avatar
69_bronco
Truck has a build date of mid Dec. 2000. Don't know if that is early or late in the model year.Couldn't find a plug that wasn't being used near the master cylinder though...
Old Oct 31, 2002 | 07:55 PM
No1Hookman's Avatar
No1Hookman
John, you won't find an empty plug, but you should find 1 large plug that has a single jumper plugged into it. Red w/white or gray tracer, I think. Your truck is an early to mid year '01. Another thing, the plugs are usually above the glove box door. Fact is, the relay bracket will screw into the header above the door. Keep looking, unless you truck is a stripper, the wires should be there. I know the XLs don't have them but an XLT should.
Good Luck, Mark
Old Oct 31, 2002 | 09:25 PM
Outpost22's Avatar
Outpost22
My old G*C could disable DRL's by simply removing the fuse.
Would it not be simpler to just add fog lights if you want daytime illumination
Old Nov 1, 2002 | 04:17 AM
Viskase1's Avatar
Viskase1
I'm with Monsta on this one. DRL's make me think GM and they never had a better idea. Besides, running lights are kind of like deer whistles on your bumper, they are not a deterent to collision.
Remember the 1953 Henry J, sold by Sears Roebuck, that came factory direct with a single white running light in the middle of the grille? It didn't work a half century ago either.
Old Nov 1, 2002 | 08:44 AM
79CEEJAY's Avatar
79CEEJAY
Old Nov 2, 2002 | 06:29 AM
No1Hookman's Avatar
No1Hookman
>to collision.
>either.
Oh, it probably worked alright, but they needed to save money, soooo...
Mark
FossenRacing
Apr 21, 2016 04:55 PM
Scotty's 52 F3
Mar 24, 2016 01:47 PM
jake22si
1997 - 2003 F150
Sep 13, 2015 03:10 PM
SVTDarin
Feb 10, 2015 02:57 PM
F-250 restorer
Dec 23, 2008 02:06 PM
