300 inline dual exhaust, behind axle exit kits
Hello--
I'm wondering if anyone know where to find/order a 2 1/4", header back dual exhaust, rear bumper or behind the rear axle exit exhaust kit.
I found one on Summit Racing, but before I could buy it they all went out of stock. Now I can't find one anywhere.
I think that this question would be better asked in the Inline 6 forum.
click here www.ford-trucks.com/forums/forum52.
Alvin--
I wasn't thinking about saving $ with a kit. The engine is being built at a residence, and without a kit or exhaust of any kind, I would have to tow or trailor it to a shop to have the exhaust welded up. I was hoping to avoid that hassle and extra expense.
So far the engine is going .o30 over, with over-size 327 SBC valves, Mild Isky cam, lifters, springs, rocker arm studs, ported and polished head, matched ports, Offy dp intake, Autolite 4100 4V carb rebuilt by Pony carbs, milled and/or decked block for higher compression, and the stock electronic HEI distributor, recurved and completely rebuilt (although I'm thinking about a DUI or Mallory Unilite unit), and Hedman headers with the locking fasteners. And oh yeah, the custom, polished aluminum Clifford valve cover which I'm sure will add at least 25 hp. And that leads us to the pistons which I haven't figured out yet.
Sounds like a solid build you have going there. The only reason I asked if you already had the headers was because my experience with headers on the 300 was all bad. They do make a little more power and torque, but they constantly leaked, and they were a royal pain to replace the gasket. I finally trashed them and went with the dual EFI manifolds, and I'm much happier with them, they are maintenace free, and you don't lose that much torque with the manifolds. I did have to trailer mine to the exhaust shop for a custom exhaust. I think you should stick with the Dura-spark distributor, it will provide plenty of spark for what you need. There is a cheap conversion that uses your stock distributor, but also uses a standard 4 pin GM style HEI module to replace the problematic Ford ignition box, and when used in conjuntion with a late model Ford EFI coil, provides all the spark you will need, good for up to 6500 rpm? (gofastforless.com). I also love the carb choice!. I run a Demon 525 4 barrel, but the Autolite 4V should work great. It's basically the same as the Motorcraft 2V, with the addition of 2 secondary barrels, and we all know what a great carb that is. Good luck and keep us posted.
Alvin--
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
2-1/4" pipe from each mainifold to a 3" Y at the firewall, then 3" all the way back exiting behind the right rear tire with a 5" stainless steel tip. It looks just like the exhaust on my 03 diesel. At first I didn't have any muffler on it, just a straight pipe. It was a lot louder than I thought it was going to be, but it really turned heads. After the novelty wore off (a couple of months), I installed a 3" stainless Silverline Turbo Pack bullet style muffler, and it quieted it down just a little bit. Still turns heads when I stomp the go pedal!. My gallery shows some pics of the exhaust.
tommyleea
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-23-2017 06:06 PM
