351W Stroker with EFI
Old Dec 25, 2003 | 09:16 PM
Breeze's Avatar
Breeze
Starting a new project. 1990 F250, 351W, E4OD, 4X4, 35" tires and 3:50 gears. Obviously with those gears and tires "underpowered" is not even close. Being as the motor is finally showing its age, I am looking at trying to draw some more power out of it. Specifically these are the mods I am looking at:
4.170 Stroker Crank (427Cid)
10:1 Compression
Mild port job on heads
bigger throttle body
headers w/true duals
Comp Cams 4X4 Cam
(Specs
*Duration at .050 in.: 210 intake/218 exhaust
* Gross valve lift: .477 in. intake/.493 in. exhaust
* Lobe separation: 111 degrees)
has anyone done a stroker with the Speed Density setup, and if so what issues will I be needing to address? I have looked at the Mass Air conversions, and they dont support the E4OD, only the regualr AOD for this application. The truck will be a driver, so I want to retain the dependability of the EFI, as well as the Cruise, OD, etc. Otherwise I would pull the 351 and E4OD and just put in a 460 w/C6 and be done with it. Any suggestions welcome.
Old Dec 28, 2003 | 11:07 PM
pinellas50's Avatar
pinellas50
I did nothing more than a cam swap on an 86 Mustang with speed density. It was a mild cam but driveability went right out the window. It had idle surge, ran so rich it made your eyes sting, and was an overall disappointment. I had to switch to mass air to make it work.
Make sure you do some serious homework before trying this!!
Old Dec 30, 2003 | 12:03 AM
fishin1976's Avatar
fishin1976
For that engine, I would go carbed with either a barry grant DEMON carb or and Edelbrock 650 - 750 CFM mechanical secondary. EFI will be a real pain to setup, many runs at a dyno and many chips burnt to make it run right. This is for mass air! Can't do it with Speed density. A carb will be cheaper to tune and then you can go to a dyno and make a few pulls and make adjustments then, not stop for two weeks to get a new chip burnt.
Just a side note: A 351w stroked to 427 CID will have some wicked rod/piston goemetry. It may not last as long as you would like it to. a 396 ( i think that the next size down) would be better and you would not give up much HP and gain some engine life. The 427 kit puts a lot of side to side pressure on the bearings rods and piston pins because of the extreme angles the rods will be at @ 90 and 270 degrees. You know that you have to have machine work done to the block for clearing the larger stroke, right?
Just my .02 cents.
Old Dec 31, 2003 | 01:40 AM
94F150-408's Avatar
94F150-408
You can check with Byron at Race Systems .com. He set up a 351 stroked to a 408 for me before. We used a 93 VEX-1 ECM out of a mustang to work in conjuction with mass air and a E4OD. This was done originally for a previous 95 Bronco I had. Now the 408 is going in a 94 truck. Not sure yet if he will have to use my VEX-1 or if the existing truck computer will be compatible with the programming needed for the 408/E4OD combo.
patrickj20
Jul 31, 2017 09:07 PM
Lilttle Red Ford
Dec 30, 2015 11:22 AM
BRay09
13
Oct 21, 2015 08:27 AM
Danny Crawdad
41
Sep 15, 2015 07:47 PM
1990f150kid
Mar 22, 2012 08:57 PM
