Final Question --> Engine goes in tomorrow
Old Jan 5, 2004 | 08:59 PM
Ratsmoker's Avatar
Ratsmoker
In order for an engine to burn fuel efficiently the cylinder must be hot. Aluminum heads dissipate heat much faster than iron therefore require higher compression to make the same amount of power. They also allow you to run higher compression without detonation. The TRW L2291 forged pistons are going to give you a tad under 10:1 and work great. There are other choices out there also. Silvolite makes a wide assortment of 390 pistons also.
J ballan
Testing.....
Feb 6, 2017 07:06 AM
fordlover801
Dec 10, 2015 08:29 AM
fordlover801
Oct 21, 2015 02:14 PM
Trevor.801
Mar 12, 2014 03:44 PM
brandon75_390
Feb 24, 2006 12:01 PM
