Best First Upgrade???
Old Dec 27, 2003 | 04:47 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally posted by gremlin25
How difficult was it to install the Hellwig anti-sway bar? Are there any modifcations to the frame or is it just bolt on?
Mine should be here in a couple of weeks, I'll let ya know.
From what I understand very easy, just time.
Old Dec 27, 2003 | 08:56 PM
VI66's Avatar
VI66
Does the sway Im supposed to feel occur while towing? If not, what am I supposed to be experiancing?
Hope you all had a wonderful Christmas!
Old Dec 27, 2003 | 09:02 PM
IB Tim's Avatar
IB Tim
Probably need a bit more information before attempting a helpful answer.
What size trailer, what type hitch are you using?
What weight is the trailer completely loaded.
Do ou know the weight of the tong.
These will help.
Old Dec 27, 2003 | 09:07 PM
VI66's Avatar
VI66
Im not pulling or towing. My question was, what am I supposed to be exp.?
Old Dec 27, 2003 | 09:42 PM
jdadamsjr's Avatar
jdadamsjr
It turns our big best into more of a sports car... where you can take turns at more than a snails pace
( and feel much more in control than without! )
What you will feel WITH the rear sway is that the inside rear tire/corner of your truck will not feel like it's about to flip over to the outside of a turn when you're going a little faster than you should !
it also helps with the side to side rocking you feel if you are running down the side of a secondary road that has dips on the right side....
Well worth it....
Old Dec 27, 2003 | 09:45 PM
VI66's Avatar
VI66
NOW I KNOW! Makes sense,
Thanks much!
