Power windows not working
Old Dec 24, 2003 | 10:15 AM
kdewise's Avatar
kdewise
Anyone know what it would cost to have the window motors replaced in the doors of an F150. Cost of the motors parts to do this myself? Also, are there any things that might be tricky in doing this?
Old Dec 24, 2003 | 12:18 PM
brown 4x4's Avatar
brown 4x4
Are both sides not working? If so I doubt both motors would go out at the same time. It almost sounds like you're not getting power to the master switch, or the switch itself is bad.
Old Dec 24, 2003 | 12:24 PM
jdolby's Avatar
jdolby
I put one in a f250 last summer. Call parts store for price. Probably under $50 bucks. As for putting one in, it isn't very difficult.
Carefully remove the inside door plastic cover. 2 bottom corner screws and 1 screw in the arm rest. (you may have to struggle and move the cover around the door handle and lock button to remove it. Use a screwdriver or a fork screwdriver to pop out the plastic plugs (CAREFUL). (the plastic plugs push into the metal holes.) They can break easily.
Peel off the insulation slowly so you don't tear it. Take out the door speaker. (leave your window up) locate the motor by feel and take out the screws in the door that anchor the motor and remove.(bottom of door) the motor may drop too the bottom of the door. Reach down and pull out the motor. Unplug the wiring harness. Careful with the window after you remove the motor screws. It may drop down.
Done
Install in reverse. Just be careful with the plastic door cover and the plastic plugs that hold it in place. Line up the plugs with the holes and give them a sharp smack with your hand. They should snap into place.
Good luck
JD
Old Dec 25, 2003 | 09:46 AM
Fully_Loaded's Avatar
Fully_Loaded
Also to make it a little easier. There are dimples in the door in front of the bolts of the window motor. Drill those out so you can get a socket and extension on them.
Old Jan 1, 2004 | 01:35 AM
peppy's Avatar
peppy
I have found the best way to fix an electric window motor...... dc the wire harness, pull out the screws and let the motor fall into the door. Then pick it up, hook up the harness, it should work fine. If it does, put it back to gether and move on. That tactic has worked for me many times in many vehicles. The motor just needs kicked.
usedtoolman
May 30, 2018 06:21 AM
new2diesel2
Dec 25, 2009 12:54 PM
brocobilliam
1978 - 1996 Big Bronco
Nov 6, 2004 12:56 PM
crazyfoolreal
Jun 16, 2004 10:31 AM
rebel_ford4x4
Sep 25, 2003 05:56 PM
