Clevelands dropping valves
Old Dec 24, 2003 | 09:00 AM
78ford100's Avatar
78ford100
I've heard stories and seen pictures of clevelands dropping valves. This seems pretty common. Were there any particular years, or models (2v or 4v) that were prone to this? Has anyone had this happen to them?
Thanks,
Justin
Old Dec 24, 2003 | 09:10 AM
beartracks's Avatar
beartracks
I've never heard of that problem. Actuall 4v 351c's are meant for high rpm use and need to have proper valve train set up. The 2v head probably don't have adjustable valve trains from the factory and this can be a problem if not addressed.
Old Dec 24, 2003 | 04:22 PM
mudcobra's Avatar
mudcobra
I've never ran across the problem either, but, most clevelands use multi grove valves allowing them to rotate, thus wearing them down and causing them to "drop". I've always been advised to switch to single groove valves and keepers when building a performance engine, thus elminating the rotation.
Old Dec 26, 2003 | 11:24 PM
78ford100's Avatar
78ford100
I'd heard of the valve keeper problem. I've been watching some other heads that really look nice, so i'll hopefully get a set. I will most likely get stainless valves put in those.
Thanks guys,
Justin
Old Dec 27, 2003 | 03:56 AM
scroob's Avatar
scroob
The only Ford engines I heard of dropping valves are the 385 series blocks with early heads. They used rail guided rocker arms. When the rocker arm and valve tip wear enough, the rails can bear on the valve spring washer, and the keeper can dislodge.
Just for the record, I own a 429 with these early heads. It has over 200,000 miles on it, and none of the rails are even close to touching.
But, it CAN happen.
Old Dec 29, 2003 | 08:56 AM
CJJTulsa's Avatar
CJJTulsa
It's not just the multi-groove keepers that make them drop -- it's the two-piece design from what I hear is the biggest problem. The valves get old, then pop the heads off. I haven't had it happen, but from what I hear it isn't at all unusual.
Old Dec 29, 2003 | 07:23 PM
grclark351's Avatar
grclark351
it's not all that unusual. all of your factory M and 400 valves are prolly 2-piece also. pop pop pop, crunch crunch crunch.
Old Dec 31, 2003 | 09:25 AM
clevelandstyle's Avatar
clevelandstyle
Yes. It is a problem with Clevelands. Not so much in stock form, but when you run stock valves in a performance application. When you put a bigger cam with stiffer valve springs in it, the heads will pop of the valves. I've done it 2 different times. I scaped 2 perfectly good engines. Word to the wise. If you want performance, put in good stainless valves.
Old Dec 31, 2003 | 03:58 PM
78ford100's Avatar
78ford100
Ok, thanks for the information guys, good responses.
Justin
George Fletcher
29
Nov 29, 2025 01:11 AM
351Cleveland C4
Dec 26, 2016 06:44 PM
nothercrash
May 10, 2011 09:16 AM
metallifanatic77
Feb 13, 2005 01:23 AM
mudcobra
17
Feb 3, 2004 09:38 PM
