351/302 block difference
Old Dec 23, 2003 | 06:35 PM
smokey-2's Avatar
smokey-2
Have a chance at buying a 3 speed w/od, that came off a 351 .
I have a 302. Will the transmission bolt up to my 302 bellhousing?
Thank you
Old Dec 24, 2003 | 02:06 AM
ddogg126's Avatar
ddogg126
It might im' not to sure.
Old Dec 24, 2003 | 07:42 AM
f100guy's Avatar
f100guy
it will if it is a 351w. with the small block bellhousing
Old Dec 24, 2003 | 09:25 AM
daerhldgs2's Avatar
daerhldgs2
what's it out of ? As the prev. reply says if it's a windsor it will , but if it's a modified it wont . the 351M has the big block bellhousing and the 351 windsor has the small block bellhousing which is common to the 300 I6 ,302,351W,351cleveland.
Old Dec 25, 2003 | 07:57 PM
duke371's Avatar
duke371
i belive the 351 c is also a big block
Old Dec 25, 2003 | 09:10 PM
daerhldgs2's Avatar
daerhldgs2
not according to my reference books, but either way not a very common motor.
Old Dec 26, 2003 | 03:13 PM
duke371's Avatar
duke371
if a 351c is the same as a 351w or 302 , how come a tranny from a 351c wil not bolt toa a 351w without changing bell houseings
the 351c has a big block bolting pattern
Old Dec 26, 2003 | 10:05 PM
daerhldgs2's Avatar
daerhldgs2
actually the 351M is a big block and uses the same bolt pattern as the 400,429 and460 ,while the 300six,302,351wand351C all share the same bell housing. I hope this clears up some of the confusion.
Old Dec 30, 2003 | 10:25 AM
iskybantilus's Avatar
iskybantilus
you are correct, 300, 302, 351w, and 351 cleveland are same, as 351M, 400, 429 etc are same.
petesparts
Oct 19, 2009 11:15 AM
joeKyTN
13
Mar 10, 2008 01:26 PM
v10squirrel
Jul 10, 2007 08:54 PM
pac_302_xlt
22
Apr 10, 2005 06:02 PM
glenn 79
Mar 28, 2001 02:10 PM
