heating problems
Old Dec 23, 2003 | 09:35 AM
jimg22's Avatar
jimg22
heating problems
i just had my expy in the shop for them to replace the high regulator valve for the suspension since it came back my heater doesnt get hot stays cool so i replaced the thermostat same prob still any suggestions
Old Dec 23, 2003 | 10:35 AM
buzzard's Avatar
buzzard
Maybe a bad/clogged heater core. I'm not exactly sure how the Expy's system works, but on past models, there is a valve in the heater hose that blocks hot water from entering the heater core when the heater is not being used. Maybe this valve is corroded closed, etc.
Old Dec 23, 2003 | 11:54 AM
jimg22's Avatar
jimg22
i took it to the dealer thry told me it was an inop blend door actuator or broken bend door anyone have any suggestions on this they told me it would cost $600 to fix most of it was labor
Old Dec 23, 2003 | 08:07 PM
AwesomeBullet's Avatar
AwesomeBullet
Since it started doing it AFTER it was worked on, I'd check real close in the area that they were in for loose or broken vacuum lines or electrical connections......
