View Poll Results: Does your 03 Expy make a clikcing sound when the brake pedal is pressed while in park
Yes
71.43%
No
28.57%
Voters: 7. You may not vote on this poll
03 Expy Brake Click
Old Dec 22, 2003 | 04:49 PM
daveplot's Avatar
daveplot
03 Expy Brake Click
Does your 03 Expy make a clikcing sound when the brake pedal is pressed while in park?
I took my truck in to the dealer today and showed them a SSM stating the way to stop the clicking of the Brake Shift Interlock. The dealer said that all Ford's click...even though Ford said there is a problem and how to fix it in the SSM.
Please click yes or no above.
Old Dec 23, 2003 | 05:21 PM
dswenson's Avatar
dswenson
Yes it does, but I never noticed it before. Probably the relay for the shift interlock. Only does it in Park.
Old Dec 23, 2003 | 08:27 PM
daveplot's Avatar
daveplot
I never noticed it before until I saw a Special Service Message about it. But now it annoys me.
16036 2003 EXPEDITION BUILT BEFORE MAY 20, 2002 -
CLICK NOISE WHEN BRAKE PEDAL DEPRESSED AND/OR RELEASED
SOME 2003 EXPEDITION BUILT BEFORE MAY 20, 2002 MAY
EXHIBIT A CLICK NOISE WHEN THE BRAKE PEDAL IS
DEPRESSED OR RELEASED. THIS MAY BE DUE TO THE BRAKE
SHIFT INTERLOCK TUNING CHARACTERISTICS. TO SERVICE,
PERFORM THE FOLLOWING AS APPROPRIATE DEPENDING ON THE
VEHICLE BUILD DATE: IF THE VEHICLE WAS BUILT 'BETWEEN' 04/08/2002 AND 05/20/2002: REPLACE THE BRAKE SHIFT INTERLOCK WITH SERVICE PART NUMBER 2L1Z-3Z719-AB. IF THE VEHICLE WAS BUILT 'BETWEEN' 03/04/2002 AND
04/07/2002: REPLACE THE STEERING COLUMN WITH SERVICE
PART NUMBER 2L1Z-3C529-GA. IF VEHICLE WAS BUILT BEFORE
3/4/2002 OR AFTER 5/20/2002, PERFORM NORMAL
DIAGNOSTICS AS OUTLINED IN THE WORKSHOP MANUAL.
The dealer decided today to speak with the tech and provide them with this SSM...to see what he wants to do.
Old Dec 23, 2003 | 09:54 PM
jhromy's Avatar
jhromy
does this noise come from the inside of the car??? I have a 2002 Explorer and I hear a spring popping noise with the car in park and i take my foot off of the brake pedal...also whe i step on it sometimes it makes like a cracking noise.
