460 conversion motor mounts
Old Dec 26, 2003 | 09:43 PM
patsplace's Avatar
patsplace
I used the L&L mounts and truck headers (2 1/2") to keep the bottom end torque and it's working really well so far. As far as difficutly installing the engine. Nada!! Smooth like peeled egg.
Pat
Old Dec 26, 2003 | 10:59 PM
muddwhumper's Avatar
muddwhumper
motor mounts and headers.
I used L&L's whole kit-headers, mounts and brackets into a 77 F-250 4x4 with that crappy power assist steering. They(the parts) worked extremely well ( although the mechanic was somewhat less than competent.)--it all went on a 460 out of a 77 Lincoln continintal. As far as I can tell no problems other than the header bolts backing out---(again that darn worthless mechanic.) L&L is expensive but the headers I got had huge flanges and there were NO frame modifications to make them fit. I specified that I wanted the headers to exit inside the frame and not the ones that went outside the frame. Although I do wonder if it would have been better to get the others--for clearance and workability around other components. I would recommend them--I think in this case you do get what you pay for. The motor is bone stock and feels like it could pull all day long.
Old Dec 27, 2003 | 09:28 AM
ranger429's Avatar
ranger429
i like the fenderwell headers. i am going to have some custom stainless mandrell bent for mine and tuck it all back under the frame and dump out with some chrome extensions under the rear bumper.
if you can afford it L+L is definetly the way to go in my book
Old Dec 27, 2003 | 10:40 AM
patsplace's Avatar
patsplace
Do you know of anybody else that has SS headers. Reason that I'm asking is that we tried them on some of the fishboats and found that the tinny noise and cracking problems made us stop using them. May be fine but that is an experinece that I've had. We ended up using that current exhaust pipe that does not seem to rust much. Think that it's got nickel in it.
Regards,
Pat
Old Dec 27, 2003 | 02:51 PM
ranger429's Avatar
ranger429
i don't know of anyone making SS headers? if that is your Q. i am going to run SS exhaust from the headers back
Old Dec 27, 2003 | 03:10 PM
patsplace's Avatar
patsplace
I was talking about the exhaust pipe that runs from the headers to the mufflesr and on from there. We found that they stess cracked quite badly and there was a sharp tinny sound. Most annoying. We may have been using entirely the wrong type of stainless and probably did.
Sorry if I gave the impression that I spoke of headers.
Pat
Old Dec 27, 2003 | 09:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hang the ends of your headers off of the transmission so the mount moves with the engine to help avoid some of the stress cracking in the headers. From there on use a ball joint and flex mounts to accomodate dimensional changes due to heat and also flex. I have seen the ball joints just not in stainless yet..
Old Dec 27, 2003 | 10:47 PM
fordlover's Avatar
fordlover
looks like the L&L headers are going to end up on the truck. Thanks for all the help guys.
U think the stock radiator will be able to cool it, or do I need to update that too?
Ryan
Old Dec 27, 2003 | 11:45 PM
patsplace's Avatar
patsplace
Thanks for the tip about hanging the exhaust with the use of ball joints. Off road does tend to flex stuff.
Much appreciated.
Pat
Old Dec 28, 2003 | 08:50 AM
ranger429's Avatar
ranger429
the radiator depends on how many cores you have, 2 core probably not, 3 or 4 core will work fine. did the truck have factory A/C or high output heater? if so your RAD will work fine
Old Dec 28, 2003 | 05:54 PM
fordlover's Avatar
fordlover
well, I have no clue if it is a high output heater or not....is there a way to tell? We put a new heater core in it a year or two ago. I am not positive on how many core it is, but that I can tell easily and will look. If it is only a 2 core, I should be able to find a junk yard swap for that shouldn't I?
thanks,
Ryan
Old Dec 28, 2003 | 07:57 PM
ranger429's Avatar
ranger429
just by a new one from a part's store, i myself would not waste my time on a junkyard RAD.
on your heater selector in the dash it will say if it is a high output heater
Old Dec 28, 2003 | 08:45 PM
  #28
patsplace's Avatar
patsplace
Gotta agree on that one. Pain in the butt when they fail and a pain in the butt to put in. For the saving of $10-$15 and that's not counting the labor of taking the swap unit out of the donor, parts store is a no brainer on this one.
As was mentioned earlier, if you've got AC you'll need the AC core. Otherwise, the High Output units are listed on the dash as having a High Output Heater. There may be exceptions but my '78 Lariat didn't have AC and did have a sign on the dash.
Pat
Old Jan 1, 2004 | 12:49 PM
  #29
fordlover's Avatar
fordlover
more questions
now I got to wondering about the weight of the 460 to the 400? Does anyone know how much more the 460 weighs then my current engine (400)? Will I need to add any extra suspension components? Maybe some air bags? I plow with this truck, so it already has extra Leafs in the front, but then again so does the rear. MY truck still has a slight rake to the front, would like to get rid of that even with the extra weight on the 460. Anyone got advice on that?
Actually, what is the difference between a high boy suspension and a stock f 250 1979 4X4? I love the way the high boy sits, any higher and I would possibly have to modify my snow plow framework. Also have to worry about Illinois lift laws too.
thanks all!!!
Ryan
Old Jan 1, 2004 | 08:52 PM
  #30
skuteman's Avatar
skuteman
Here is a general type question for anybody who has a Comment. I've got a 77 Hiboy with a relatively low milage 400 with about 3500 miles on a complete rebuild. I've considered putting a 460 in its place to try and improve the fuel milage. I have a NP 435 . I know the 400 bell will bolt up to a 460. MY Question...... Will the 10 spline X 1 1\16" output shaft from the NP435 along with my clutch assembly bolt up to the 460 flywheel without alot expense , etc. thanks, s.kuteman
