Using Oil that is too thin????
OK. Let the bashing begin!!!
I just run 10w30 year round. It seems to work well.
You're not crazy. Supposedly, 5w30 and 10w30 will have the same viscosity when hot. But since 5w30 starts out with a 5 weight oil instead of a 10 weight, I think it does wind up being a little thinner.
I don't think that anyone has ever demonstrated an engine problem caused because of metal-to-metal contact because an oil is too thin. Many racers use a straight 10 or 15 weight oil when qualifying on a track to pick up a few extra horsepower. And those are high-performance, highly stressed and expensive engines.
The only practical reason I see for going with an oil over 30 weight is in high mileage, worn engines or engines with larger design clearances like diesels or some air cooled engines. Not a squeaky-tight modern engine like the Ford 4.6/5.4L.
If they leak oil, fix it, don't add STP!
Happy Holidays!
Now, speaking dino oils and pushrod engines, if you want to run a 5w30 in winter, fine, but why run it in the summer? A 10w30, since it starts with a thicker base oil, will have fewer viscosity index improver polymers and thus would be less subject to viscosity reduction from polymer sheer than would a 5w30. That's why you don't see either 5w30 or 10w40 heavy duty motor oils (I suspect diesel engines can really give motor oil a beating). My local Ford/Sterling dealer tells me the big trucks run 15w40, except in the winter they run 10w30.
Do viscosity index improver polymers sludge up an engine when they shear, or do they just improve the viscosity index to a lesser degree?
I understand another reason for the thinner oils is because the newer Ford overhead cam engines need to have the oil supplied quickly to the camshaft way up in the top of the head. Maybe so, but Ford had OHC four bangers for many years before the thinner oils were specified.
In either case, we need to determine two things first:
Is the greater engine wear caused at startup when oil is thickest and flowing the least, or could it be under conditions of maximum heat and stress?
And even if an oil dropped to an SAE 25 from SAE 30 after VI additive breakdown, is that *really* a potential problem? (regardless of what the TV motor oil ads claim). Like I mentioned, a lot of racing cars with expensive, stressed out engines use much thinner oils than what we might ordinarily use.
We're all here to learn and do the best for our vehicles, it would be helpful to know the answers to these questions.
Mobil recently came out with a synthetic in 15W-50.
IMO, that's a completely ridiculous product with no practical benefits. Strictly a marketing scam for which they should be embarrassed. No one needs an SAE 50 engine oil, especially a synthetic. Just because they're making it, doesn't mean that a thicker oil offers any benefits. Unless you're leaking it or your engine is on the way out from wear. And I wouldn't waste my money on a synthetic in a worn out engine.
If someone likes gooey oil, STP or Motor Honey will do the same thing for a lot less money.
Andy Granatelli made an awful of of money over the years selling STP promoting the idea that a thicker oil was somehow better for an engine. Maybe it was true with the engines of 50 years ago, maybe it was never true, but the concept sure sticks in our minds, doesn't it?
618400 - DRIVEABILITY IDLE - ROLLING IDLE
SPECIAL SERVICE MESSAGES
17268
1994-2003 MULTIPLE VEHICLES WITH 7.3L DIT - IDLE ROLL/LOPE ON COLD START
SOME 1994-2003 SUPER DUTY F-SERIES/E-SERIES AND 2000-2003 EXCURSIONS EQUIPPED WITH THE 7.3L DIT ENGINE MAY EXHIBIT AN IDLE ROLL/LOPE ON COLD START THAT LASTS UP TO ONE MINUTE. THIS CONDITION IS CONSIDERED A CHARACTERISTIC OF THE 7.3L. THE FOLLOWING STEPS CAN BE TAKEN BY THE CUSTOMER TO REDUCE THE LIKELIHOOD OF THIS CONDITION: CHANGE TO A 10W-30 OIL (XO-10W-30-QSD) LABELED CI-4 OR CH-4; PLUG IN THE BLOCK HEATER WHEN OUTSIDE TEMPERATURES ARE GOING TO BE BELOW 30F (-1C); LEAVE THE IGNITION IN THE RUN POSITION FOR A FULL 2 MINUTES SO THE GLOW PLUGS CAN FULLY HEAT THE CYLINDERS BEFORE CRANKING THE ENGINE.
I think that longivity is not a concern with racing engines as they get frequent rebuilds.
You obviously know what you're doing and take good care of your truck with that straight-6.
I'm only trying to sort out and discuss the issures related to the original question, which was if a 5W-30 type of oil provided adequate all-season performance. I might have driven this off the track, and for that I apologize, but IMO the answer is yes. I wouldn't question the use of the recommended Motorcraft 5W-20 semi synthetic oil in a modern 4.6/5.4L V-8 engine or the 5W30s that are out there, which also seem to have a synthetic component.
IMO, using an oil rated at 5W-anything should provide very good strartup protection on a cold engine, where I believe most of the wear occurs. Jell-o offers no engine protection and bypasses right around oil filters until the engine warms up.
One of the most interesting products I have seen is the new Mobil 1 0W-40 synthetic. If it has minimal VI improvers added, it could be about the perfect motor oil. Everyone had to decide for themself if the price is worth it or if it offers tangible benefits. You know it's going to provide the hot oil pressure of a 40 while pumping fast and being all over the inside of an ice cold block in January. OTOH, I like my engine heaters, too.
I wondered if the oil could be too thin. So, I changed it and put in Mystik JT-8 10w30. This eliminated the piston slap completely. It runs nice and quiet now. I suspect that any non-energy conserving 10w30 oil would have given the same results.
I realize this is an unscientific experiment, and that this is only the results on one vehicle. However, my ears dont lie, and the noise is gone.
Jim
Yes, at least the older ones did. That is the main reason 10W-40 was disapproved for warranty a long time ago. "Black death" was the name given for that type of sludge.
Jim
It's only a matter of which gets you first!BTW, would not a 5w30 be another Black Death oil in the earlier days? I think it has about as much VIIs as 10w40.
