Sponsored by: Real Truck
ride problems (expansion joints)
Old Dec 26, 2003 | 11:12 AM
Dave Sponaugle's Avatar
Dave Sponaugle
About 2 or 3 hundred pounds of sand bags all the way at the back of the bed will help get rid of the bounce slap syndrome of concrete highways. This is a lot cheaper than shocks and all that. That big hole in the back is where you are supposed to put stuff, and stuff weighs more than air.
I think the soft ride update is called "Crown Victoria"
Old Dec 26, 2003 | 12:54 PM
Tlattin's Avatar
Tlattin
Very well put, Dave. You are on the right track.
Old Dec 26, 2003 | 06:26 PM
Dave Sponaugle
I am retired from over the road truck driving. Go try running down the road in a bobtail (no trailer) big rig. Loose things inside the cab become projectiles on concrete highways. Trucks were designed to have something heavy back there.
Old Dec 27, 2003 | 11:30 AM
maddog7's Avatar
maddog7
sandbags in bed
Will this still work if the bags are up against the cab, or do they have to be back by the tailgate.
Old Dec 27, 2003 | 04:47 PM
abendx's Avatar
abendx
tailgate
Old Dec 31, 2003 | 01:33 PM
harald's Avatar
harald
I've done two things to my truck that improve the ride. The easiest and cheapest is to run the appropriate tire pressure for the load. I usually run around with no load, so I don't need the tire pressures listed on the door jamb (which is for a fully loaded truck). By weighing the unloaded truck and consulting a tire inflation table (try www.trucktires.com), you can set a lower pressure that really improves the ride compared to running 80 psi.
The other thing I did is install the Rancho RS9000 shocks. I put them on to reduce sway when hauling my camper, but they also soften the ride unloaded if set to the lowest setting.
steveg_nh
Sep 27, 2017 11:20 AM
twigsV10
Jun 4, 2016 12:10 AM
hickorycornerfarm
Jan 31, 2012 04:13 PM
russellbailey
Dec 15, 2010 07:49 PM
vidrine2
Jun 23, 2007 05:49 AM
