Sponsored by: Auxito
2003 SuperCrew Headlamp adjustment
Old Dec 22, 2003 | 09:32 AM
arptspt72's Avatar
arptspt72
Question 2003 SuperCrew Headlamp adjustment
I have a new, 2003 Lariat SuperCrew. Been getting "flashed" alot while driving. Sure enough, I noticed that my left headlamp is way high from the factory. I see the 2 hex head post on the lamp assembly but I notice no obvious effects when I try to adjust.
Am I adjusting the correct adjustment? Also which of the hex head posts is the vertical adjustment? I hate to sound so incompetent but assistance is greatly appreciated.
Old Dec 22, 2003 | 10:27 AM
karenj's Avatar
karenj
The inside hex is the verticle. You need to be on a some what level ground, point truck (head lamps) towards a wall or garage door Aprox. 20 to 30 ft. away, you will see your head lamps on the wall and you will see the bad one, then adjust. If that is'nt good use a reference line horizonal, tape works good. Hope this helps
BIG BRD
2004 - 2008 F150
Sep 29, 2014 08:29 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 30, 2014 07:22 AM
robkyle
13
Sep 11, 2013 05:38 PM
mzimmers
1997 - 2003 F150
Apr 18, 2005 03:51 PM
JKP87
Apr 22, 2000 04:50 PM
