headlamp adjustment???
Old Mar 16, 2004 | 11:52 PM
BIG BRD's Avatar
BIG BRD
how does one go about re-aiming the headlamps if the truck was to say, lifted about 6 inches?? not that mines is lifted but i just did an hid install on my headlamps and the beam is about 5 inches higher than normal. Am i missing the adjustment screws or is there not any, cause i didn't see any?? thanx leroy
Old Mar 16, 2004 | 11:55 PM
ohankeuylian's Avatar
ohankeuylian
what kind of Hid lights did you put in.. i want to get the ones that show blue and bright as hell.. let me know.
thanks
Old Mar 17, 2004 | 12:46 AM
BIG BRD's Avatar
BIG BRD
well hate to say it like this but i rigged it up! first off i lost the high beam option but i dont care. i pulled the bulbs and the ballast (ignitor) off of an audi that i happened to come across in my line of work. tapped into the ground and low beam wires and thats it. seem to be working other than the fact that they are aimed a little to high. ive gotta ?? for anyone who has dealt with hids or know anything about them, does the bulb have to be with the stick pointing in the up direction, i know im not describing this the best way possible but if you have seen a bulb you know what i am talking about. Maybe if i turn it sideways or down it will change the height of the pattern. just a thought
Old Mar 17, 2004 | 04:25 AM
MiamiE's Avatar
MiamiE
good mod thats what i have now also.
Old Mar 17, 2004 | 06:44 AM
kingfish51's Avatar
kingfish51
It does say in the owners manual on how to adjust the headlights. They are only height adjustable. Not side to side..
Old Mar 17, 2004 | 08:31 AM
AlamoFlyer's Avatar
AlamoFlyer
Has anyone found a reasonable cost (Not HID), high output (blue/white) headlight lamp that will replace the stock 9008 lamp in the 2004 F150 S-Crew? The only thing I've found on the web is from Australia and can not be exported to the USA.
Old Mar 17, 2004 | 06:47 PM
MiamiE's Avatar
MiamiE
no 9008 or H13 bulbs are out yet.
Old Mar 17, 2004 | 07:06 PM
kingfish51's Avatar
kingfish51
And that bulb is the wrong one. It is an H7, not an H13.
There used to be a 9008 bulb for a Saturn, if I remember correctly. I did a search for the 9008 bulb and kept coming up for onr for a Saturn.
Old Mar 17, 2004 | 07:33 PM
BIG BRD's Avatar
BIG BRD
damn, i should have read the owners manual like they told me to when i bought my truck but did i read it...NO, have i read it after the last post...YES. thanks kingfish51.. when i installed the headlights yesterday i didnt see an adjustment screw i looked at them again today and what do you know!! thanks guys for your help!! leroy
Old Sep 29, 2014 | 08:29 PM
kellsu22's Avatar
kellsu22
H13 HID SYSTEM reasonable cost
I have a hid system in my truck it's from DDM TUNING. it's under $60 for the whole wire harness, ballasts, bulbs. It also comes with a lifetime warranty.
The website ddmtuning.com
It's pretty simple to install. Just a plug and go type system.
Hayguy
Nov 12, 2016 11:04 PM
jbiloff
Oct 16, 2016 10:09 PM
smcrea
Aug 24, 2016 07:43 PM
Puckhog
Aug 5, 2016 11:28 AM
fballguy
Mar 13, 2016 10:37 PM
