turn signals not working
Old Jun 4, 2010 | 10:50 PM
Jerry Edwards's Avatar
Jerry Edwards
turn signal not working
My windshield wipers stopped working,the wire to the wipers at that plug somebody crimp conected right at the plug,i moved the wire and the wipers worked and signal worked on and off.So i checked the plug,it was corroded,i cleaned it and the signal/brake light worked.This is the big square plug below the master cylinder,the wires on one end runs up to the block of 2 relays on inner fender,one of which felt like it was for the turn signal.
Old Nov 25, 2019 | 11:46 AM
ericl72's Avatar
ericl72
Originally Posted by firestroker8706
That sounds to me like the relay under the dash that was described a few posts earlier. I had the same thing happen and that's what it wound up being. I don't have my manual on me right now but hopefully someone else will chime in with one. If not I'll try and get it to you this weekend.
Turn signal doesn't work? This relay controls the flashers and turn signals.
I Know that the latest post is 2010, but this helped immensely. There are 2 relays tucked up under the dash approximately above the drivers right knee. I replaced that with a generic relay from the parts store.Thanks!
Old Nov 25, 2019 | 08:56 PM
jimjokjv's Avatar
jimjokjv
My turn signals quit working a while back. Turned out to be the connector plug at the switch. The wires inside were no longer held firmly in place so only sporadically making contact. I simply put a drop of super glue on the metal pin where it was supposed to fasten to the plastic. So far everything is working fine.
Old Apr 9, 2020 | 11:27 AM
Steve Robins's Avatar
Steve Robins
Turn signals not working and brake warning light is on
04 F-350 turn signals not working on dash or on truck everything else is working I have replaced the blinker relay and the multi switch on the colume 😡😡😡please help losing my mind
Old Apr 10, 2020 | 02:01 PM
kbeefy's Avatar
kbeefy
Is your '04 a 7.3? I looked up an '03, My '04 wiring Diagrams only list 6.0. Not sure if it makes a difference...
Front and rear signals out? Brake lights work?
Fuse 27 under dash is front lights and Cluster, Fuse 18 is brake and rear lights, if I'm reading it correctly.
Old Apr 10, 2020 | 03:01 PM
FordTruckNoob's Avatar
FordTruckNoob
Maybe he's from Australia or some other country that had the 7.3s well past 2003?
Old Mar 2, 2021 | 02:28 PM
cooldealpickle's Avatar
cooldealpickle
I have a 99 f250 super duty. My signals wouldn't work, but hazards and everything else would. I had good continuity from switch to relay and from relay to fuse panel. Had power at 10a fuse 23 under dash. (Far right-second one down) It will only have power when in run. White wire with light blue stripe from fuse panel to relay for signals. Light blue wire(#44) from relay to signal switch. Found that the fuse read good power, but when I'd let off it would lose connection. The fuse socket was loose inside. I could move the fuse and signals would work. I broke a prong off a bad fuse and jammed the fuse up against the loose one and tightened it up. It'll do for now. Pain in the butt to find though. I hope this helps. Not sure if the wiring and fuse details are the same on your truck.
Myfirstnewtruck
1997 - 2003 F150
Dec 13, 2023 03:01 PM
Blue Rebel
Apr 6, 2009 09:41 PM
earl964
Jun 25, 2006 07:00 PM
jwebbn
Electrical Systems/Wiring
Mar 12, 2005 08:29 PM
Peganit
Aerostar
Feb 28, 2004 10:17 AM
