no turn signals
Old Jun 7, 2004 | 03:17 PM
jwebbn's Avatar
jwebbn
Cool no turn signals
I have a 1988 F-150 f/i 302. It has a single flat fan belt. The belt broke and after replacing it my turn signals do not work. I can turn on the hazard lights and they work fine. I could sure use some help. I cannot find any reason for it.
Thank You
Old Jun 7, 2004 | 04:13 PM
87 XLT's Avatar
87 XLT
Probably a bad flasher. Take a look at the fuse page in your owners manual, it will tell you where the flashers are. E-flasher & turn signal flasher are probably the same so just switch them with each other & see if the turn signals work. Since the E-flashers use the same bulbs & wiring the only other thing it could be is the multifunction switch. If it's not the flasher, check continuity thru the multifunction switch.
Old Mar 12, 2005 | 02:02 AM
bobcat_85's Avatar
bobcat_85
no signal lights
have replaced flasher canister, still no turn signals, need help, no wiring diagram, and no fuse layout.
Old Mar 12, 2005 | 08:29 PM
Franklin2's Avatar
Franklin2
Do your brake lights work?
