Sponsored by: Auxito
Wierd Trans Vibration
Old Dec 21, 2003 | 10:26 PM
Eddieslilmule's Avatar
Eddieslilmule
Hello All, i have a 1997 F150. When i get on the gas and the trans drops to the lower gear for more RPM's, the problem is when it kicks back into the high gear, the trans kind of vibrates and then kicks in. Some times it vibrates and sometimes it doesnt.
Please help
thanks
eddieslilmule
P.S. and if you dont understand please let me know.
Old Dec 21, 2003 | 10:59 PM
JeremyH's Avatar
JeremyH
Check the tranny mount to make sure it is still in one piece.
Old Dec 21, 2003 | 11:38 PM
LxMan1's Avatar
LxMan1
How long has it been since the fluid was changed? These tranny's are prone to this if the fluid isn't changed about every 30,000 miles or so, as recommended in the owners manual.
It shounds like torque converter chatter to me.
Jimmy
Old Dec 22, 2003 | 09:21 AM
50th ann's Avatar
50th ann
I purchased a 98 F150 4.6L new and it has done pretty much the same thing very 30,000 miles or so. A fluid and filter change clears it up. I've heard this is a common problem but regular maintence will keep it from happening. Be careful when removing the filter the rubber O-Ring on the neck will stay up in the transmission and the new filter will not stay in place until it's removed. Carefully pop it out with a small blade screwdriver, but don't scratch the housing in the process.
My question of the day is - Why don't they put a drain port in the transmission pan?
Old Dec 22, 2003 | 09:25 AM
Racerguy's Avatar
Racerguy
50th ann here's a little tip for you. Instead of using a screwdriver to pop out the o-ring try using the round (ratchet) end of a 3/8" drive extension. It works really well and wont scratch the bore.
Old Dec 22, 2003 | 10:19 AM
50th ann's Avatar
50th ann
Thanks Racerguy. I have about 5000 more miles and I'll be crawling under there again. This time I'll have my ratchet extension with me.
Old Dec 22, 2003 | 10:30 AM
Joe Finn's Avatar
Joe Finn
Do you guys recommend taking the vehicle to Ford for a flush on the machine or is dropping the pan for a filter/fluid change good enough?
What about drilling the pan and installing a drain plug kit?
Old Dec 22, 2003 | 10:38 PM
Racerguy's Avatar
Racerguy
Having the tranmission flushed is a good way to do it but then so is dropping the pan and draining it that way. There is also a plug on the torque convertor so you can drain that too. Both ways will do the same job but if you pull the pan you can replace the filter too. Quite often when shops flush the trans they dont touch the filter.
Adding a drain plug is a good idea. I think that B&M and maybe Transgo make plugs for them. I'm sure others do too.
Talyn
22
Nov 30, 2013 10:57 AM
hugging corners
Jul 16, 2009 02:07 PM
ford user
Dec 25, 2006 12:59 PM
ejpreston
1983 - 2012 Ranger & B-Series
Jul 18, 2004 09:39 PM
dragracer
Jun 9, 2001 09:40 PM
