Where To Put Tow Strap
Old Dec 20, 2003 | 04:37 PM
njxlt's Avatar
njxlt
I have a 98 XLT and need to pull out some equipment. Where is the strongest spot on the Expo to put a tow strap hook? Anybody hook up a tow strap to their truck before?
Old Dec 20, 2003 | 04:46 PM
98EBExpo's Avatar
98EBExpo
I just use the trailer hitch...
Old Dec 20, 2003 | 07:49 PM
FTE Herman's Avatar
FTE Herman
Me too.
Old Dec 20, 2003 | 08:52 PM
daveplot's Avatar
daveplot
I use the trailer hitch or tow hooks
Old Dec 20, 2003 | 09:55 PM
MisterCMK's Avatar
MisterCMK
I would say the hitch or tow hooks as well. The tow hooks are meant for it, and the trailer hitch is meant for pulling trailers.
Old Dec 21, 2003 | 08:44 AM
myblkexpy's Avatar
myblkexpy
The strongest point is definitely the hitch.
If you use the front tow hooks, make sure you pull straight on. I saw an expy with a twisted frame from pulling the front hook at an angle. Thought about tying the two frame members together to get more strength out of the front hooks. Anyone have an opinion?
Old Dec 21, 2003 | 10:14 AM
njxlt's Avatar
njxlt
Does anyone know how much the max weight is on the front hooks? Does Ford list this anywhere?
Old Dec 21, 2003 | 05:15 PM
tsdrallyer's Avatar
tsdrallyer
Trailer hitch! Last winter I pulled out a 5 ton wrecker which was stuck to it's frame in mud. Due to the bolt arrangement it may only have a 500 lb tongue load, but it will pull behind it 10K lbs befofe straining the drive train. I'd guess the hitch and frame could pull 25K lbs in a straight line if the truck could only do it.
Old Dec 22, 2003 | 03:24 AM
philrush's Avatar
philrush
these guys are right. Hitch or tow hooks.
One tip..... a "******" strap is worth its weight in gold when pulling a heavy load out of a difficult spot.
Old Dec 22, 2003 | 10:24 AM
buzzard's Avatar
buzzard
I like ****** too.
Dick Kranz
Jan 25, 2015 02:41 PM
CTC01
Offroad & 4x4
29
Jan 4, 2014 02:27 PM
JOHN2001
42
Dec 1, 2013 04:41 PM
rrawlins
Offroad & 4x4
44
Dec 22, 2003 12:53 AM
