335 Ford
Old Dec 19, 2003 | 01:02 AM
EXOPAR's Avatar
EXOPAR
335 Ford
Hey Guys
Does somebody knows about Ford 335? Have a good chance to purchase a very good deal on this enginee but need to know if this is a W,C or M based engine.
If so it may be a good project to swap a 335 using 302 Fi parts.
Is it possible to use this engine with 302 heads, Fi and all that stuff......?
Really need to know prior to make an offer..........
Old Dec 19, 2003 | 07:37 AM
jwtaylor's Avatar
jwtaylor
I am not familliar with a 335 cubic inch motor of the ford variety. Do you mean 335 series? If so that includes the 351cleveland, 351 modified, and the 400 modified. You could use the cleveland heads either 2v heads or 4v heads on a windsor 302/351 windsor motors with some machine work. YOu could also modify the 400 crank to create a couple stroker variations on the 351windsor. Honestly, unless your getting these parts for free, the cost to rework, might not be worth it considering all the aftermarket cranks and heads that are available used to add performance to the windsor small blocks. To tell the 351cleveland from the 351/400modified motors the bellhousing is a small block pattern on the cleveland and the modified engines generally have a big block bolt pattern. To tell the 351m from the 400m you have to measure the stroke or know whats stamped on the crank. If you wanted a performance motor then the 351cleveland would be great. Just a thought, let us know what you have, I am interested in knowing what a 335 cubic inch motor came out of, if its not 335 series, later
Old Dec 22, 2003 | 11:15 PM
EXOPAR's Avatar
EXOPAR
335
ook
Finally have found what a heck is a 335.
It is a 351 engine with smaller pistosn 3.850 mainly found in some F600 series assembled in Mexico.
I think this engine should made a nice project muscle power plant since there is a lot of matterial that can be cut out of the cilinders.
Question here is: What is the bigger I can go in therms of pistons with this 351 based block?
Second question is if 351 head on a carburated engine can be swap in a 302 Fi?
Third question is how big can I go in therms of valves?
Is someone has info to share it will be higly appreciated.
Regards
Ray
Old Dec 23, 2003 | 07:48 AM
jwtaylor's Avatar
jwtaylor
If your talking a 351 with standard stroke of 3.5" and a bore of 3.85 then you would have a 326 motor.
3.85 X 3.85 X 3.5 X .7854 X 8 = 325.96456 cubic inches
Where did you get the info for the 335 engine? I would like to look at it.
I wouldn't know how much you could bore that block is it identical to a regular 351, as far as cast, just with smaller standard bores?
Just for thought a 351 can be bored out to 4.060 but its recommended not to go past 4.030/ 4.040 just to be sure the wall thickness doesn't become too thin and create too much heat/ overheating.
YOu could swap 351 heads on a efi motor you may have to modify the emissions equipment to fit. If you going with late 70+ 351 heads forget it, they are the same thing as a 302 head, as far as, port design.
1.94/1.60 is a good valve upgrade you could go larger but you might decrease your piston options. later, lemme know more about that 335
Old Dec 23, 2003 | 10:59 PM
EXOPAR's Avatar
EXOPAR
What I have been able to measure at te pistosn is 3.85, I am asuming the crank is 3.5 (but it may be not).
The only think I can say for sure is that this is a 351 based engine made in Mexico by Ford to be used during 70's and 80's in the F600 truck series.
I know those are a reliable engines with a very decent fuel consumption, now the fact is that I have this engine for free in a very decent condition.
Piston Std
Cranck +0.010
Journals +0.010
And overall very decent operating conditions.
Now what I would love to do is to assembly a powered engine out of this 335, the choice here is what rout to go?
If any sugestion, please feel free to comment.
Regards
Ray
Old Dec 24, 2003 | 08:33 AM
jwtaylor's Avatar
jwtaylor
Well I am still not sure what you have, but the usual applies, add the best flowing heads you can afford, bump the compression, add a cam that works with the engine components and vehicle its in, feed it the right amount of fuel and it should move up the road pretty good. later
Old Dec 24, 2003 | 01:53 PM
pud's Avatar
pud
there was a big block FE series 332, it was the same block as the 352. It employed a 3.3" stroke and a 4" bore, 10.17" deck height 2.02" intake valves, 1.55" exhuast and 6.54" rods with a really tall compression height of 1,938-1.953". Produced in 1958&1959. 225/265hp@4400/4600rpm, 260/325ft.lbs @ 2800/2200rpm.
The 335 series consisted the 351c 351m and 400.
Old Dec 24, 2003 | 10:33 PM
f100guy's Avatar
f100guy
boring cylinders will is meant to clean up the bores, not to gain power because it won't. the only thing you gain is extra heat. trust me i know i have a 302 bored .060 over and i have to use a 3 core and it still gets between 190 and 230 cruising.
Old Dec 25, 2003 | 09:21 PM
There Goes The Neighborhood's Avatar
302 blocks are notoriously thin, and shouldn't be bored past .040 over, because the water jackets become too close to the cylinder wall. The radiation of heat from the thin cylinder walls to the water jacket is causing the overheating. The 460 in the race truck is bored .060 over, and only gets over 205 when the radiator core is blocked from airflow.
Country4.2
Ford Truck Parts for Sale
Apr 12, 2014 10:34 AM
goodwrench1
13
Jan 16, 2014 06:39 PM
wyldstallyn73
Mar 27, 2005 12:11 AM
335clevo
May 27, 2002 06:48 PM
335clevo
Sep 26, 2001 05:25 PM
