Sponsored by: Kumho
lugnuts, beveled VS flat surface
Old Dec 18, 2003 | 09:29 PM
rangedog's Avatar
rangedog
My 98 Exp. has alum. wheels and the mating surfaces of the lugnuts are a flat washer, therefore they are not self centering. Why is different that the more common cone type lugnuts?
Old Dec 18, 2003 | 10:50 PM
rebocardo's Avatar
rebocardo
I "believe" it goes like this:
On cone type lug nuts, the lugnuts center the wheel. On later Fords the wheels are hub-centric where the hub centers the wheels, carries the weight, and the lugnuts just clamp it down and prevent it moving off the hub.
Aluminum wheels with steel cone/acron lugnuts tend to loosen up after a while. Also, hub-centric aluminum wheels with flat faced lug nuts do not need steel reinforcements around the stud area. Or something to that effect.
plgebbia
Mar 3, 2023 01:34 PM
acameron1934
Jun 1, 2017 07:48 AM
Mgjfam
Jan 25, 2017 03:19 PM
PartsPaul62
Nov 6, 2011 08:30 PM
CuNmUdF250
Apr 19, 2011 11:33 AM
