runs rough
Old Dec 18, 2003 | 03:27 AM
dreamtruck's Avatar
dreamtruck
runs rough
I have a 351c 2v auto in 68 f100 new plugs and wires,dist,carb. Its missing really bad shakes violently at idle smooth at freeway speed.slight popping out drivers side at about 35.:
Old Dec 18, 2003 | 08:35 AM
dogdays's Avatar
dogdays
check your firing order.
R.
Old Dec 18, 2003 | 06:40 PM
cantedvalveFord's Avatar
cantedvalveFord
Could be a multitude of things, the question is much too general, sorry can't help much without seeing truck in person, but here goes:
Look for vacuum leaks, plug gap closed, wires off, cracked cap, cracked rotor, bare/shorted ignition wires, carb/float level. Backfiring out exhaust can mean too rich a mixture, can also mean it's way out of time, or you can have a burned exhaust valve too...
Try a compression test and leakdown test also. Have someone put the engine on a 'scope and check the ignition if you can't nail it down.
and/or about 25 other things could cause it...
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
